hey guys. havent been on in a while. i ahvent really unicycled much, ive been filming for my new solo pogo video, almost every trick hasnt ever been landed, theyre lal my original tricks, so ive been working really har don that.
but anyways, the results of me trying really hard to land these tricks results in me falling, and my body cant take much more, so im taking a little break from pogoing, it hurts to walk or do anything, its just too much.
so because of that, im going to be devoting alot of time to unicycling. i can ride it easily, i can do peg taps (idk what its clale din unicylcing, but you lower the uni down to where the pedal hits the ground then you pull it back up) and i have landed a 180 unispin very few times. i am currently learning to ride SIF and SIB and learning to grind.
i was wondering, when you guys grind, is it only the pedal that grinds or is it the crank too?
If you do drops, grinds and stuff I would recommend to use real trial/street uni. There’s some good and durable unis except Nimbus have weak cranks. This is pretty good and cheap trial unicycle and this is pretty good uni too.
