Ok so long story short, jumped down a set, sorta messed up and landed sideways…severely bent my kh 20…It’s still rideable…but not “hoppingdownstairsable” lol.
So its time for a new unicycle. Since I cant afford a new kh 20, and don’t really want a new 300$ wheelset I just want a new 20.
Now I already have a 24 inch dx, and I LOVE it. Wonderful unicycle.
But I am honestly kinda 70% going for the Nimbus.
What do you guys think? That nimbus, or a dx. If I go with the nimbus, should I drop 30$ into the kh crankset/hub? Or is their stock crankset still plenty strong enough.
If it helps my weight is 175.
But like I said I’m already for the nimbus mostly, but if theres any reason you think I should go for the DX please let me know! : )
thanks for your time!
I also hope this does not discourage anyone that’s planning on buying a kh 20 from actually buying one. My rim is bent, but that unicycle took many massive drops for 2 years. I guess it just finally couldn’t take it anymore. Its still a great unicycle and ill miss it : ( lol
I’d definately get the Nimbus trials if your getting a new uni. Same strength, more compatible with other parts, and better upper half for sure,
so basically the Nimbus is better in all aspects.
saskatchewanian is right. You should probably just go with the Nimbus wheelset, because it’s pretty much the same as a KH wheelset.
But if you refuse, get the Nimbus. It’s strong and you may not need the KH cranks. I’ve been bending the lightweight Nimbus cranks, but they now come with Venture cranks. The bold paragraph on the Nimbus 20" page used to say that you might need to get moments, but now it says the venture cranks are pretty good.
