Way to win an argument. Which of us is supposed to have no physics experience? We both ride unicycles so we both have a lot. I don’t know the math side, and I will not argue with your equations.
But c’mon. Are you suggesting you are less emotionally attached to this than someone else? If so, what I see in your video must be described as really good acting.
Naomi obviously did. Who are the supposed physics professionals here, besides yourself? If you ask me, a non-physics professional, you simplified your experiment to the point that it’s not very meaningful. All it does is suggest the buildings should have fallen slower. I agree, it sure seems like they should have.
Like those bees. A religious argument? How about a science argument? Science says the bees can’t fly. But the annoying fact is that they can. We know this because they do it. Therefore, God isn’t necessarily mucking around with science, we just don’t understand the system in its entirety. Apparently the same is true with the collapsing towers.
Whatever you did prove with your equations, you did not prove why the buildings fell faster than people thought they should have. What is the official speed of a collapsing building of that design? Nobody knows. In this case, it seems faster than anyone would expect.
You offer us a bunch of physics equations, which brings you to the theory that the buildings fell too fast, then you insist there were bombs. Why bring science in at all?
And yet what happened in real life is what’s in these hotly contested videos. You’re starting to sound a big unhinged.
But they didn’t fall in freefall time, correct? You said 11.2 seconds for what should have been 10? So how much did the twin towers weigh? Certainly enough to do quite a bit with that extra 11.2%.
And even if there were enough explosives down below, to create a controlled demolition as some suggest, how much could that have speeded things up? I think the “official” theory is that once the mass of the upper floors was allowed to collapse one floor, nothing was going to stop it. and the design of the buildings, with the central shaft and hard corners, offered little resistance to this type of force.
So if we both agree on all that, what we’re getting down to is the 11.2% vs. the higher numbers postulated by your non-breaking floors equations. Now make your floors out of sandstone or something similarly brittle, and see what happens then. Hard to calculate with clean equations? I can only imagine. You might have to do a real-life test. If someone did an accurate-enough test of this nature, it might start to prove something.
Yeah, maybe.
