As confirmed by the “next comp poll”
Standard rules apply, must never have landed it before.
Must show proof that it was 60cm or more.
Must land it clean and ride/hop away.
Here’s the trophy: *)—60cm sidehop-*O
Favorite Tricks: not much, learning to wheel walk, jumping off of stuff
Note to the competion: i r teh n00b!
Rules are, if you have already jumped up something 60cm or more, you cannot be in this competition, so all of you that are below 60cm, then youre good.
I dont understand the flat to flat question. Im sure if you jumping from something slanted to something else flanted, and as long as the height from take off to landing is 60cm, you should be good.
But really its very simple, just go film yourself jumping up a 60cm ledge, stack of pallets, stairs, or whatever measures up to 60cm.
Ok so then it is UP to something, not a side hop ACROSS from flat to flat. I was only asking for clarification since “side hop” can mean both across or up. When I hear the term side hop I usually think of side to side; across, not JUMPING UP to something. I thought 2’ across seemed way to easy.
Oh right. Thanks for the clarification. I think I’m a little too new a unicycling to enter this one. I dont think I’ve managed to hop onto anything above the 2nd step of some standard sized stairs. So maybe around 25-30cm. Lots of practicing to be done! Enjoy the comp.
