I used lights once, but don’t remember the wattage. Can you MUni with a 5W bulb, or is that asking for trouble?
Re: 5W light bright enough?
My 6W setting is ok for Muni. I even use that for mountain biking (uphill).
It’s only at higher speeds that you need more, (minimum of 12W for downhill
mountain biking). 5W should be ok for Muni although the option to have more
sometimes is always a good thing. There’s no real way to know if it works
for you but to try it.
—Nathan
“Sofa” <Sofa.9qnmb@timelimit.unicyclist.com> wrote in message
news:Sofa.9qnmb@timelimit.unicyclist.com…
Sofa.9qnmb@timelimit.unicyclist.com (Sofa) wrote in
<Sofa.9qnmb@timelimit.unicyclist.com>:
Hi
I use a 5w/10w pair and my brother is using a 5w single. Both work fine
(if I had my time again I’d have saved the money and only bought the 5w
single).
Phil from Melbourne
