as far as i know there is only one frame that takes 42mm barings in the uk and thats the kris holm
i want to build up a 29 muni but the only frame i could use is a kris holm which is a bit expensive for me in the us i think the nimbus 2 is 42 but it says its 40 on udc.co.uk i need 42 as i have a hub i will use that takes 42 can any one help me with my problem??
cheers guys
Well, this one has 42 mm bearings (doesn’t say whether they are machined), so you should be able to get just the frame.
Call them and work it out.
i fancy a flat top as they look better but i will take that into considiration cheers
alex
You can use 42mm bearings in cheep stamped 40mm bearing housings. (like the old pre-ISIS Nimbus frames) It has been done many times.
I have not done it yet but plan to in about a month when I upgrade my Muni wheelset.
