40mm bearing extractor
will a 40mm bearing exrtactor work for removing a 42 mm bearing?
depends which puller you have, got a link?
yeah here
No problem
Removing it will ruin it, so make sure you have new ones ready. Put the axle in the freezer, then when it’s cold, press the new warm bearings on with a pipe that can only touch the inner race. A cold axle is a little smaller then a warm one.
yep agreed, that one will do either size.
thanks guys
