OK so it seems that the question “which 36er is best for me” keeps popping up, I recently directed someone to a post from 2008 without realizing how out of date it really was. Anyway I figured I would collect some basic info on what is on the market as of January 2013 to help people decide what to get. Keep in mind that not all unicycles are available in all countries and product names (and configurations) are not 100% consistent across the world.
Coker Cycles
The offerings from Coker all have:
Super wide 48h square taper hub (40mm bearings, 128mm spacing)
V brake compatibility
25.4mm seatposts
38mm double walled rims
choice of tires
Coker Big one:
Regular style aluminum frame
Coker V2
Same as Coker Big One but with a Cro-Mo “squid” style frame.
Heavier and stiffer than Coker Big One. Possibly stiffest (and heaviest) frame on the market.
Qu-Ax
The Qu-Ax 36ers have:
48h regular width ISIS hubs (not all hubs identical)
25.4mm seat post
12g spokes
Qu-Ax 36
Regular style steel frame
V-brake mounts
31.5mm double walled rim
Rim does not have a flat breaking surface
QX Series Marathon
Hydraulic brake mounts
42mm double walled rim
QX Series Disc
Same as Marathon except:
Disk brake mounts and cable guides
Nimbus
The Nimbus 36ers have:
36h super wide hubs (127mm bearing spacing)
42mm wide double walled rims
25.4mm seat post
Nimbus Titan (US)/UDC Trainer (UK)
Square taper hub
no brake mounts
Nimbus Nightrider
Square taper hub
triangulated Cro-Mo frame
Magura brake mounts.
Frame has great torsional strength but is a bit flexy laterally
Nimbus Nightrider Pro
Same as Nimbus Nightrider but with:
ISIS hub
Nimbus Impulse
Same as Nightrider Pro but with:
Disk ISIS hub with aluminum spindle
Disk brake adaptor and cable guides
Hydrolic disk brake included
Nimbus Oracle
Same as Impulse but with:
Kris Holm Unicycles
KH unicycles have:
Regular 36h ISIS hub
Magura compatibility
42mm double walled rims
Double hole cranks standard
KH-Schlumpf compatible
Pre June 2012 KH36
See above
Post June 2012 KH36
+ solid disk brake mount
Disk brake cranks
Triton
Triton unicycles have:
Hand built titanium frames, built to order
Bling factor
Mega Muni (Mountain Uni
Regular style titanium frame
Magura and disk brake mounts
Mountain-Uni disk brake system
Custom
Whatever you want, but be prepared to wait
Cheep amazon/eBay 36ers
Soft square taper hubs, single walled rims, noodley frames and suspect parts. They might be OK for a bit but be prepared to have something fail catastrophically (a much bigger deal on a 36 than a smaller wheel)
Other custom unicycle manufacturers:
If you are getting a custom unicycle built you probably know what you want
What it all means:
Frame material: Aluminum is quickly becoming the predominant 36er frame material. It is light, stiff, corrosion resistant and relatively cheap but eventually wears out as it can only handle so many “stress cycles”
Steel is still real, particularly when talking about chromoly (Cro-Mo) steel. Unless it rusts out a steel frame will likely outlast an aluminum frame and is easily repairable if it does break. It is a relatively heavy and flexible frame material though.
Titanium is light, strong, doesn’t get fatigued like aluminum, or rust like steel but costs substantially more.
36h or 48h: a 36 spoke wheel will lighter than a 48 spoke wheel but a 48 spoke wheel will be stronger.
12g or 14g spokes: It looks like Qu-Ax is still using 12g spokes. These are thicker than regular (14g) spokes which will be heavier but make a stiffer wheel
Regular width or Super wide hub: A regular hub has 100mm bearing spacing, a Superwide hub has 127mm (±2mm depending on manufacturer). A Super wide hub will give you a stronger wheel build by having greater flange spacing. This forces you to have a wider stance which is generally offset by using zero-Q cranks. In theory a 36 spoke supper wide will be slightly stiffer laterally than a similarly tensioned 48 spoke regular width wheel. You will need a frame that takes a regular width hub if you want to run a Schlumpf hub.
Disk hubs will result in a dished wheel build, which won’t be as strong as an equivalent symmetrical wheel build.
ISIS - vs - Square taper: ISIS is a spline interface which results in a stronger connection between cranks and the hub.
It used to be much easier to find short square taper cranks for road riding but ISIS cranks have since caught up and possibly surpassed square taper cranks in this reguard. There is now little compelling reason to get a new unicycle with a square taper hub unless you have specific cranks you want to be able to use with it.
ISIS hubs use 42mm bearings and Square taper hubs use 40mm bearings so you may not be able to put a ISIS wheelset in a non ISIS frame etc.
Magura - vs - V brake - vs disk brake: Magura brakes are hydraulic rim brakes; they are more expensive than conventional rim brakes but very smooth. V brakes are what are found on most non disk mountain bikes. They are cheaper than maguras but can work almost as well if set up properly.
Disk brakes are relatively new in the unicycling world but have the potential to be both very smooth and powerful. Internal disk systems (Nimbus, Qu-Ax) mount on the left side of the hub, moving in one hub flange resulting in a dished wheel but allow the use of virtually any crank you choose. External disk systems mount the disk to the crank (KH, Mountain-Uni) requiring either a custom crank (KH) or disk (Mountain-Uni) but allow the hub to remain symmetrical and does not exclude the possibility of a Schlumph geared hub.
Rim width: Wider rims tend to be stronger, give a more stable ride, and allow lower tire pressures. Skinnier rims may do better with road crown with certain tires.
Feel free to chip in if I missed anything or if I got something wrong.
