Hey, I finally got my replacement hub from Florian.
When I first got the geared KH36 it was built with an Airfoil rim.
Then the bearings failed and I had to send the hub back to Switzerland…
Having a Nimbus Stealth Pro rim on my Nimbus Nightrider I figured I could save some weight (I think about 100 or 200g?) on the guni by swapping rims with the Nightrider.
So I just unlaced both 36ers and built the Nightrider’s Super Wide Hub into the Airfoil. I assumed 3 cross was about the only normal way to do this and so it worked alright like that. Although the spokes came through the nipples quite a far way. And it took forever. But I’ve been riding it like that for a while now with no problems whatsoever.
What I didn’t realize is that the geared hub and Airfoil wheel had been built up 4 cross, as I found out by studying a close-up picture of it…
So now when I got the new hub I thought I’ll just build it up 3 cross as well.
It sort of worked but the spokes (371mm) came way too far towards the rim tape.
So I thought I’ll take care of that and dremeled them all about 3mm shorter.
At first that seemed to solve the problem. But when I got to the stage of tensioning it up properly I found there was barely enough thread left to get it right.
I did get it tensioned very slightly and thought that it might be enough.
But when I did a small cautious test ride one spoke ripped out of the nipple.
So I don’t think it can be trusted for high speed distance riding.
That took about all day yesterday and now it turns out I’ll have to get new spokes anyways and do it all over. Bummer.
So now that I know I’ll need new spokes no matter what I found out with the spoke calculator on Roger’s site that I would need 377,8mm for 4 cross or 362,45mm for 3 cross.
I can only find 376mm or 371mm anywhere. They are way too expensive at 1,40 EUR per piece at municycle.com so I’ll get them either from Roger (0,67 EUR) or from the Danish site (0,56 EUR) instead.
So it looks like 4 cross and 376mm is my only real option, right?
Should I get some extra long nipples or will I be OK with 376mm instead of 377,8mm?
Any other tips before I order?
