Oh, ok. I thought what I did was a single seat wrap with each leg, and when it went behind you, it was just a plain wrap. But thanks for the correction. I guess I can do real seat wraps too, and I might have put one on there… but I only had about 15 minutes of battery life on that camera.
yeah im not really sure what you did is called but a seatwrap is when you go behind.
if you can do what you did without hops, you should be able to seatwrap.
Yeah, I can go behind without hops too. I have a really hard time with it though. I don’t know why, I think I make it harder than it should be. But I’ve done it quite a few times. It’s a cool trick.
Yeah I guess there’s a lot of stuff I should have filmed… But if I waited to charge the camera, it would have been dark by the time I got back out. I can do some pretty smooth flatland stuff, and I came up with some cool street lines, and I guess I can coast now. Oh well, I really just wanted to get a couple 360’s on film.
Unispins aren’t hard at all. Really all it takes is commitment. I’ve seen some of your videos, and I’m sure that if you just set your mind to do one, you could.
