36” tyres opinions please
Currently have a nimbus nightrider lite on my 36er.
I wouldn’t mind getting a spare 36” tyre what is everyone’s opinions on the tyres that are available.
My riding style is canal paths so a varied mix of terrain.
Vee Tire T-Monster (on Nextie 36" carbon rim) is a nice ride. M4O and Unicycle.com sells them but they are likely also available through other non unicycle dealers.
Personally I hate noisy knobby tires on asphalt but to me suprise it’s very silent and smooth. So far I have only ridden it on asphalt as I am still riding some easy routes on the 36" (it’s my first). Btw. I ride it at approx 45psi (~3bar).
It’s a very tight fit on Nextie rim and I would rate it as one of the most difficult tires I have tried to mount (and I have done a lot in my many years of two-wheel riding). But as others also mentioned that is an advantage as the tire is then less likely to blow off the rim.
Another option is the Qu-Ax King George Ultimate but I think it’s very likely that it’s essentially the same (Innova tire) as as the Nightrider Lite except for the thread but maybe @rogeratunicycledotcom can/wants to confirm or reject that observation.
For reference the Nightrider Lite is indeed a Innova tire as of now.
I am familiar with the nimbus nightrider lite and the king george ultimate (I have one of each on my 36" and my G36, both with brauss carbon rim). I have a preference for the KG utlimate, I feel a real difference when turning. It’s not a matter of weight. There is 30g between my two tyres (the nimbus nightrider lite is 1250g and the KG ultimate is 1220g).
EDIT : I use them almost exclusively on the road (sometimes also on towpaths). I always ride on rolling terrain and inflate my tyres to between 35 and 50 psi (never below, never above, I weigh 70kg fully clothed). At the moment I’m on 35 psi with my 36" and the nimbus NR lite, as I’ve already had a tyre blowing problem. I will soon order a KG ultimate as a replacement (I use this unicycle to commute in town and to ride on mountain roads, I climbed the Mt Ventoux this summer).
I just got the king george ultimate and i will write a review of it in a few weeks time. I can only compare it to the standard nightrider, but I want a nightrider lite too, so I can compare all 3 for a review.
Im looking forward to the next containerfull for unicycle.uk, se and de.
… with the NR lite; What happened?
I always feel a bit anxious first time pumping up a tyre and hardly dare go up to the recommended max 3,5 bar on the KG ultimate.
It’s a tire I’ve had for a long time (since the nightrider lite is available on the market). I left my unicycle in the car in the sun after climbing the mont ventoux last july. Since then, it is damaged, it threatens to blow out again.
Thats not good news for my NR lite that blew off my Nextie this week. I wonder how it would fare in a hooked/dominater 2 rim?
