I have a steel rim on my nightrider/coker mix right now and it makes the thing a beast to ride, any rim lighter than the old steel rims is what I’m looking for.
thanks!
A current model, strong and light, is the Nimbus Stealth 2, worth getting prebuilt if you can afford it because then you can upgrade to ISIS cranks. Maybe you can find a Stealth 1 if someone upgraded…
i would build i myself, and I have a nimbus superwide square taper hub right now with a mountain uni disc brake; changing to isis would mean changing that unfortunately. the stealth rims look very nice though
