My buddiy recently bought a 29. We both have been riding it and comparing it tour 24 KH mUnis. We have 165’s and 170 cranks on our 24’s. I completely understand why you would want 150’s on a 29 if you ride the street, but does it make sense to use a crank that short if all you plan on doing is rough trail riding?
We keep having a problem with the 29 just stalling and dumping us over the littlest twig and roots. Will longer cranks help with this?
It depends how rough. Really. If it’s the same trails, you should have longer cranks on your 29 than on your 24. That said, I’m running 160s or 145s on my 24, and 160s (currently) on my 29, though I seldom ride the 29 as I’ve been using a Coker.
Possibly, but little bumps you can see are a matter of technique. The bumps will still be the same if your cranks are longer; technique is what you use to keep you rolling over them.
The way i see it is, if you have shorter cranks on a bigger unicycle you will have less leverage over bumps, but the wheel size should compensate for that and roll over them.
I cope fine doing muni on my kh29 with 150s… but it all depends on what sort of muni you ride I suppose.
3 of use tried this thing and we all said the same thing. It just seems to stall in the smallest dip or undulation on the trail. When we go back and look at what dumped us and we can’t believe how minor it is. It does fine on the bigger stuff you can really see. I’m wondering if it the difference in tires, We have the 3.0 Duro on our 24’s they seem to monster truck right over everything, Skinny little Weirwolf with low pressure on the 29. I got some 175’s cranks I may try on it also.
I think longer (than 152 mm) cranks will make it worse because they will teach you to slow down to clear little bumps. What you need to do is learn to carry your speed through them.
In my experience, cranks in the 137-152 mm range are the most ideal for 29er MUni. Anything too rough for a 29er with 152s is also too rough for the available wheels/tires.
I would stick with the 150s. You really don’t want anything longer than that, even for muni.
Something else to consider would be a tire with more volume, which will help a lot with going over things offroad. What kind of tire do you currently have on your 29er? I love the Kenda Navegal for offroad, it made a world of a difference switching to that from the nanoraptor.
EDIT: I see that you already posted that you have the Weirwolf. I still think that the Navegal will be better than the Weirwolf b/c those WTB tires are so thin (especially the sidewalls).
When the little stuff knocks you off it’s usually because of pedal position. The same bump without your cranks vertical and you’ll roll right through it. In other words, technique. Technique will improve with practice, as will your ability to read the trail. There will always be invisible bumps (and gaps in concentration), but you’ll learn to spot more and more of them.
Exact crank size recommendations are not particularly useful unless you know what the terrain is. I have 160s on my 29" because whatever I had on there before was too short for the technical terrain I wanted to ride through. But on easier trails I’m using 125mm cranks on a Coker.
If you apply the leverage rule too literally, then the equivalent of 6" cranks on a 24" uni is 9" cranks on a Coker. How many of your ride Coker with 228mm cranks?
The style of riding is different. My 28 with almost no tyre to speak of will often roll over stuff although I use only 114mm cranks. I only suffer on steep hills, especially descents.
That seems to be the issue, I was pretty tired, been riding single track for several hours when I jumped on the 29. I kept getting caught in little undulations on the trail with the crank arm around the 1 o clock position where you are just pushing straight into the crank. Didn’t know if longer arms would help a little to get it thru the rotation. Bad/sloppy technic may be the case.
I’m usually pretty good about keeping momentum. Expert level MTB rider, and I usually ride Single Speed 29’s.There all about momentum too.
Without Janet Jackson and partner there wouldn’t be wardrobe malfunctions. I’m still wondering. If it was a malfunction, what was that costume supposed to do?
I have 165s on my KH24 and 125/150 dbl-holes on the KH29. After putting the WTB Stout on the 29er (which has a pretty significant weight penalty over the Exiwolf I’d been running), I’ve been thinking about getting a set of the 165/137s for it.
The trails I ride are pretty rocky and rough, and at first I thought I’d made a mistake in even buying the 29er. But it didn’t take long to adapt to the bigger wheel and shorter cranks. Just keep riding it, especially when you’re fresh, and you’ll get the feel. The speed, especially, is noticeably more fun than the 24; it feels much more like biking. Of course, I don’t have a particularly fast cadence, so if you’re pedaling like an expert XC racer already, your speed on the 24 is probably already faster than me on the 29.
I rounded up some old Shimano 175mm cranks off a old MTB bike, and took the 29 out for a test drive in the woods. The 175’s definately helped ME with the dead spot. No they are not as fast, Not even close, Q factor also grew a full inch, but I can climb up alot of steep stuff way better. We have alot of short quick ups and downs here and the trails are VERY tight and twisty. The 175’s didn’t feel weird, it felt kinda good to be turning a big circle, just like the big circles I turn on my MTB. I did notice how slow I could go also( I can make this thing move at a turtles pace), downhill control was off the hook, I was able to lower the seat a good bit, thus giving a lower center of gravity/ ride feel. I think for the trail riding that I do, 170’s may be the way to go. Going slow with a ton of extra leverage did not seem to be a bad thing for me.
I ditched the Exi, and stuck on a Geax Suguaro I had laying around. It has the biggest Volume of the current Knobby tires according to our MTB Tire GURU Shiggy, here 's a Linky… http://mtbtires.com/specs/700.html This is a good smooth rolling small knobby tire with a fairly soft compound. It also didn’t seem to fold as bad as the WTB Exi.and it is much lighter with a Kevlar bead. Just for the record with all these changes the Uni weighed in under 12 lbs.which felt pretty light when riding and jumping.
