Anyone have a 29er frame banging around? Not too picky, but I’d like something that will fit a 29x2.35 tire. I’ll be running a square taper hub so I can shim if I need to fit larger bearing holders. Brake mounts aren’t necessary either.
If I can get something for around $20-30 shipped I’ll be happy. If you have something worth more PM me, and maybe I just won’t be able to pass it up.
Either of the Nimbus frames (round/flat crown) will work. I had a flat crown Nimbus 29er that fit the Big Apple 2.35 with plenty of room to spare. That tire measures bigger than many of the knobby tires in the same size range.
If there was a used KH, or other frame that turned up for a bit more I would certainly think about it.
