28" frame.
It’s easy to extend a United ($34) frame to fit any wheel you want. Just cut the
legs, insert the required length of extra steel tubing (10 speed handlebar
material works great!), and stitch it back together.
Chris
“Dibble, John” wrote:
> I have a 28" (700C) wheel that I built on a suzue hub with the best of
> intentions of welding up a uni frame from some aircraft tubing I have lying
> around, but have somehow not managed to do so.
> Given my obvious slothfulness, I ask the group for recomendations on a strong
> stiff frame for that will accept the wheel. Optimally, I would like to use the
> Miyata bearing holders but I am not married to it.
> Suggestions?
> John
Suggestions?
John
RE: 28" frame.
That is a very interesting idea! I do have a bit of machining equipment.
(Sherline minature lathe and mill) I will look around for what I can find! jd
-----Original Message----- From: Arthur Doerksen [mailto:adoerksen@home.com]
Sent: Friday, September 29, 2000 4:33 PM To: unicycling@winternet.com Subject:
Re: 28" frame.
“Dibble, John” <John.Dibble@us.luxfercylinders.com> wrote in message
news:9D2E4E2FD8C9D211BFC600A0C9B6B17F8B503C@ALPHA2
lying
like
> to use the Miyata bearing holders but I am not married to it.
> Suggestions?
If you can machine a bit, you might try a mountain bike suspension front fork
with the Miyata bearing holders bolted onto the bottom. Some suspension forks
are quite adaptable for this, with straight bottoms that are almost flat. The
Miyata holders give you the extra height you’ll need. A local bike shop has some
for as little as $75 Canadian ($50 US) from MTB’s they have upgraded.
Blessings!
Arthur Doerksen
Re: 28" frame.
lying
like
> Suggestions?
Blessings!
Arthur Doerksen
