26" Nimbus Muni, 24" Nimbus 'Cruiser', 26" Nimbus frame
The time has come to do what was once unthinkable. The following must go:
26" Nimbus Muni. Light to moderate XC use (no gnarly stuff). Nimbus ISIS 36 hole hub laced to the Nimbus alu rim. 3" Duro Leopard tire with moderate wear. 150mm Nimbus Venture cranks with nice low-profile, glass fiber, sealed bearing pedals (PB?). Magura rim brake (rebuilt by ‘Brycer’ here in the unihood) with KH Spooner. Standard Nimbus alloy seat post. Old KH Fusion ‘air’ conversion saddle (worked fine for me). Free Maxxis Hookworm tire with very little wear. ** Looking for a local Seattle-area buyer ** First $250 takes it away.
24" Nimbus ‘Cruiser’. 2nd owner. Nimbus ISIS 48 hole hub laced to a Nimbus blue ano aluminum rim. 145mm Qa-Ax1 cranks. 2.5" Maxxis Hookworm tire with moderate wear. Blue Nimbus gel saddle is worn at the usual spots but works as intended. Standard steel seat post. ** Looking for a local Seattle-area buyer ** First $160 takes it away.
26" chrome Nimbus frame (pre-ISIS, uses older 40mm bearings). Wide enough for a 3" Duro Leopard tire! Very little use. No brake mounts. Includes Nimbus square-taper 36 hole hub. 152mm black ‘MBX’ cranks. $45 + shipping to the lower 48. Local pick up welcome.
Adult-owned. This stuff has not been abused and always stored indoors. PM me if interested. I’m not able to check PMs during the day but I’ll respond as soon as I can.
Thank you.
I’m interested. PM sent.
LanceB
Interested in 26 . … see PM.
PM sent too about the hub & frame.
26 stuff is no longer for sale but the 24 is.
