This might seem like an ignorant question, but here it goes:
I have a 29"/700c unicycle that has Magura mounts placed for meeting up with the 622 bsd (29"/700c) rim.
If I am not going to use a brake, is there any reason why one might not try out some different (i.e. smaller) wheel sizes in this uni?
I have a lot of 26" and 650b rims and large MTB tires (including a Pacenti Neo Moto 650b MTB tire) and thought I might build up a few wheels to try the different sizes.
Am I correct in my understanding that this will simply lower the unicycle a little bit, a most requiring I raise my seat post by the difference from what it would be with the 700c/29"/622bsd wheel?
Assuming you use the same length cranks you won’t even need to change the seat hight, as the seat will always be the same distance away from the hub for all wheel sizes used.
I had normally used a 24 inch muni wheel, and always wanted to try 26 and 29 inch wheels. So last time I upgraded, I went to KH 29" frame. Have swapped wheels several times, and eventually came back to the 24" being my favorite. The 29" frame works out great, allowing me to swap to those other wheels anytime.
