I have an Onza witht he stock rim, and I am in need of something a bit wider. The problem is that right now I can’t spend too much. I was hoping that maybe someone might be willing to part with a wider rim that still has some useful life in it. An older or heavier rim would be fine it just needs to be able to run with low pressrue w/o folding as much.
My tire is mounted right now so I don’t know the inside width, but the outside width is about 32mm.
I really only need the rim, and maybe spokes, but I plan on using the same hub.
I suppose I assumed 36 was pretty standard. You’re right that I shouldn’t assume anything. So, for anyone who has an old rim that may need a bit of straightening, or not, I would be happy to discuss a 36 hole rim you have sitting around.
