So I have a 2013 torker dx 24 It has 22x41.5x12mm bearings, I want to get a nimbus frame for it but noticed they fit 22x42x12mm bearings. Will it still fit?, if not is there a solution? Also, how hard would it be to convert the wheel to twin 32mm bearings to fit an impact gravity 24 frame? is it even possible? Thanks
You just need to find something .25mmโs thick to use as a shim. I donโt have any on hand, but I think 2 layers of soda can aluminum should get you in the ballpark.
