2010 KH 36, Ti Hub, Superlight, $750
I am selling my custon KH 36, built by Josh at UDC in 2010 using the original welded KH Ti hub and red nips. It is super light and super strong.
This uni has very little use, probably fewer than fifty miles of light duty use, as you can see from the tire, the little rubber nips are all still there, minimal scratching on frame, cranks, and bumpers, essentially a new uni.
I am selling this uni with some crank options. Currently the uni is outfitted with QuAx 170’s, which are super light and very powerful for hill climbing. I have a set of 165/135 Moments and a set of 135 Moments which I can include for an additional fee.
$750 plus shipping from Tennessee, 37830, or pick it up and save :slight_smile:
Add $60 for the 165/135 dual hole Moments
Add $50 for the 135 Moments.
PM with questions.
Saddle: KH Grey Freeride, Second generation KH design base with front lift handle
Seat post: KH Adjustable 27.2 x 350mm bolt on style, sand blast black, pinned and bonded rectangular mounting bracket, 4 hole
Seat post clamp: aluminum single bolt, black
Frame:KH “clear coat” 36" 7005 aluminum with a butted seatpost tube through the fork crown, Machined bearings, and Magura brake mounts
Hub/axle:KH Moment ISIS, 36 hole, TITANIUM, 100 mm center bearing to center bearing
Spokes:14G. stainless Black (371mm in length for 3X), red nips are custom
Rim: Nimbus Stealth 36", 36 hole, 38mm wide, machined sidewalls for smoother braking
Tube size:36" x 2"
Tire: Nimbus Nightrider multi surface tire, max air pressure 65psi
Crank arms: QuAx 170’s, optional KH Moments 165/135, KH Moments 135
Pedals: Odyssey Twisted PC Black Nylon 9/16"
Bearings: 22mm x 42mm
What, nobody wants to buy a KH 36?
What is this world coming to…
Id love to run it but its big $$$$$$$$
Yeah, but it’s a KH, it’s nearly brand new, and it has a Titanium hub :smiley:
Yum, yum, yum!
OOOO man such a awsome uni!
To bad im a broke ass student id just on that deal right away
Need a lighter 36 er maybe later on if its still available
Maybe you could get a loan from your parents :smiley:
Just tell them it’s for a good cause and that it’s a much healthier hobby than playing video games or doing illegal substances :wink:
this or a n26 hard choice!
Price Drop: $700 plus shipping from Tennessee (37830)
No longer selling with crank options, price is sold as is.
