I have a 20" Yuni with a Sun double wide rim.
My ? is will I have enough clearance in the frame to turn this into a trials unicycle with maybe a 2.5" tire
Thanks
ashley
you have a 20" sun doublewide? Iv never heard of one… but the 20x2.5 tires use a different sized rim, called a 19" rim. Your frame will however have the clearence for such a tire.
so i cant do it ?
I think you’d need to get a whole new wheelset with the 19" rim.
This type of wheelset would fit in your frame, but the trials tires will not fit on your current rim.
Nikki
Will the KH 20" wheel set work for this?
yes it should, that is it your refering to this one: http://www.unicycle.com/shopping/shopexd.asp?id=664
I have no experience on the matter personally, but i have heard others say it works.
