I have 127 KH/onzas on my trials uni which I never ride anymore. I like them alot more than the 140 '04 KHs I used to have.
Right now I am riding koxx 110s on my splined freestyle thing and its nice. Short cranks are nice to a certain point then they start being a pain. With the 110s I slip out all the time but they flip realllly fast.
The longer the cranks, the more control you will have. With the 140 mm cranks you will have a much better time with trials because it will take less effort to control the wheel. The smaller the cranks the more likely the wheel is to roll out and cause you to lose control.
What you also have to remember is that street and trials are two different things. Although they may have similar elements and you CAN use the same rig for it, they tend to put different forces on the wheel.
For street you tend to be rolling almost all the time, or at least for good flow you should be, and therefore smaller cranks make sence because you can roll faster and with less jerking forces to make you think about.
For trials to be honest MOST (damn thats probably gonna bite me in the ass) people aren’t rolling around a heck of alot except on skinnies. This means that when jumping up on onto things you are going to want a wide base stance that will alow you to spread out your balance and keep from slipping out and such. This is where longer cranks help a great deal, they also help when you land on an obstacle and your wheel is not completely ontop of it. With shorter cranks you are likely to slip out and not be able to have the force to keep balanced in that stance, let alone push onto the obstacle.
I currently use 110 cranks and I am finding that although my street is greatly improving. On the other hand, I find it extremely hard to land on any obstacle that is smaller than about 10 cm, unless I am landing paralell to it. Whenever I do I roll out and hurt myself. I have also ridden larger cranks many times, and I often borrow friends unis for more difficult lines so I do have experience with both.
I know I’m no John Foss or some other crazy all knowing uni god, but those are my experiences.
I have a Odyssey sevenka rim and I’m not sure what the tire is but I am pretty sure its a 20x2.1". Soon I am planning on getting a twenty-g tire for it. It’s supposed to be just a little smaller than a trials tire. I am riding it with a bedford frame and CF seat so I think its much better for the urban flatland/freestyle kind of stuff. I don’t even ride my trials uni anymore:o
For flip tricks it makes the flipping part easier but the landing is alot harder. Especially with double flips, once those short cranks are spinning its hard to land back on them without slipping out. I have that problem with outflips too, they just want to keep going. Longer cranks would make stuff like that way easier to catch.
Here is a pic of my uni without a seat (ignore the random stuff to the right).
[/mild threadjack]
Many thanks! (and sorry for the mild threadjack :o )
I have 102mm cranks on my freestyle uni, so the 140mm on my trials uni (Koxx Devil) are quite a difference. My feeling is that the longer cranks make some streetstyle tricks (like 360 unispin) much harder (larger momentum and the feet are far away). Some other people told me that the bigger area of the cranks is an advantage.
I think I may get some 127mm cranks when a new ISIS model comes out.
I’m slightly confused, this is what that link says about the tire: “The Twenty-G is an astonishing 20" x 3.45". Quite possibly the fattest 20 inch cruiser tire on the market. Also features a lightweight design keeping you rolling fast and smooth, so if you’re looking to phatten up your ride, this is the way.”
I’m not sure, but I think 3.45" is bigger than 2.5". Is that really what your getting?
I am not sure about the long cranks making unispins harder but unispins are so much easier on that freestyle/street uni its crazy. There is alot less room to land on (My trials has 127 KH/onza cranks with the q-factor) but it spins so much easier. Most of that is probably from the skinnier tire and that it weighs alot less. When I was riding the trials I couldn’t do any unispins over 360 at all, it just fell over. When I got this uni I landed a 540 unispin in probably 10 minutes. The short cranks probably helped a little bit.
I prefer my 140s for trials. I was riding it with 125s before and though it did offer speed it dropped alot in control. I found that skinnies were easier and i had alot mor control on drops with the 140s.
However i ride just trials so my opinion is slightyly biased. I think it depends what you do more: Tirals= 140s, Street=127s.
what if you got cranks that were 136s or sumthing like that.would’nt that still give you speed but still a little more control than the 127s…or would that even work?
135mm I think would be the perfect ideal crank size. I have 145’s on my trials, and they are great for trials, but anything else they are a bit cumbersome. I can live with it.
140’s or 45’s for pure trials is fine, the leverage and control helps a lot. It’s just more stable, esp. with natrual trials.
i like the 127’s on my dx, i can zip around nice and quick. I couldn’t imagin having huge 140’s on it, it seem unpractical for a 20". i have pleanty of tourque for trials and whatnot
