No, not the normal boring stuff, like being harder to balance, hard work up hills - what are the peculiar issues you just wouldn’t have thought of. Here are a couple prompted by today’s ride:
unicycles keep going for a lot longer when tumbling down a steep sideslope after you bail
you can’t one wheel drift a unicycle (well I can’t anyway)
Blow downs, fallen logs on the trail. Much more effort to roll hop or static side hop over compared to a bike.
We’re always in the wrong “gear” for the terrain. Too spinny on the easy flats and downs, too low on the climbs. Can’t just change gears (even with a 1:1.55 Schlumpf Hub ) to match the terrain perfectly.
Hidden, leaf covered holes on the trail. While a bike can just jar and bounce through holes, these hidden tiger traps are the bane of offroad unicyclists!
berms sure look like a lot of fun until you 1:1 pedal on them
cant “pump” the terrain
gravity
no freewheel (which makes for a nice quiet ride)
you can’t use clips
no suspension (in most cases)
we have to work to go downhil
A hard brake will faceplant you.
Having to endure: “HEY, You’re missing A WHEEL” at least once per ride.
Having to respond: “It takes twice-the-man to ride half-the-bike.”
6000:1?! Hell no! Pedal 6000 times to go forward one revolution? No way!
Assuming you meant 1:6000, that would be nuts too!
gravity
you can’t use clips
Much harder to avoid pedal strikes.
flats are harder to change
Can’t put your feet down to push through terrain while riding.
