Learning to ride
Recently I was very encouraged by the positive comments made by several experienced unicyclists to the learner-videos I produced of myself learning to unicycle. they are here
Further encouragement from Klaas Bill and CBS has reminded me that I made notes to accompany each video I produced - and I wondered if these would also be interesting for other learners to read. At the risk of my notes appearing a load of cod’s wallop here are bits that accompany two videos. If they are of use I can upload the others. Please remember I remain open to correction - I am a leaner.
HOUR 1
Balance and unicycling
At Hour 1 it is worth noting some experiences. Firstly the balance principle. I found this intriguing because I couldn’t find a ‘point’ of balance to aim for as I sat on the seat. No matter how I leaned there wasn’t any feedback for balance.
In retrospect I can see I was thinking ‘bicycle’ not ‘unicycle’. On a bicycle your whole weight may be on the pedals and it is possible to stand up on the pedals as you ride - especially going up steep hills.
As a learner on a unicycle the point of balance is achieved by transmitting body weight through the seat and the seat stem. Legs are used to turn the pedals - not to lift your weight onto them. To a beginner like me this is a strange feeling - it’s like relaxing the top of your body whilst tensing the bottom half. Experts clearly develop further abilities but this account is designed to communicate with people who have never tried a unicycle. So, it focuses on my experience as a beginner.
By relaxing my body weight onto the seat and feeling this transmitting through the seat stem I began to get some sensation of balance or at least reference to the wheel under me. Simultaneously I also felt growing awareness of control, albeit partial, through the position of the cranks - whether vertical or horizontal.
Looking where you are going is another technique that I have trouble with. When I looked ahead up the road I kind of lost orientation with the unicycle. I didn’t have any references with the road - because the unicycle is your link to the road - but it is underneath you and it can’t be seen if you don’t actually look down! Looking ahead is like floating free along the road - that I found somewhat disorientating. On a bicycle you are normally aware of the machine and can still see the handlebars and front wheel when you look up the road.
However, I believe this points to one of the major pleasures of unicycle riding i.e. ultimately you ride along the road with a sense of freedom from the device that is enabling you to go along the road!
Now I have to practice looking ahead and also sitting up straight - I believe these two thing will come hand-in-hand. I am also eager to develop control of the cranks using the legs.
HOUR 3
Wow! discovered today how to ride faster as follows:
The saddle position has a lot to do with balance and also how sensitive the machine is. Push the seat backwards and the unicycle becomes slower to respond to pedaling motion. Push the seat forwards and the unicycle becomes twitchy and over responsive.
Think of it like this:
To go faster you have to lean forward then as you fall you pedal faster to keep the unicycle up. However, when you are sitting on the seat there is a balancing point between leaning forward and leaning backwards.
If the seat is set forwards to ‘twitchy’ the balance point is extreme. between leaning back and leaning forwards there is hardly any middle balance point. So one second you are leaning back and if you compensate by leaning forward the balance point shifts at light speed and you fall off.
This has to be damped by setting the seat backwards enough to dull the over responsiveness but not so much that the unicycle becomes sluggish to pedaling faster. This position is found by experimenting with the setting that is personal to each individual. I found my setting today.
Now I have got a compliant unicycle that is happy to come to life when I start pedaling hard. When I slow up the unicycle becomes passive and allows me to do some good balancing acts at almost full stop - way to go!
However there is more. As a beginner it is natural to expect both feet to be planted on the pedals whilst the backside is firmly planted on the saddle. If this is not so you simply fall off the unicycle as you loose control. Now I have discovered that is is possible to shift the feet as well as the backside on the seat. This is done by essentially having the cranks horizontal and stopping the unicycle from moving as you balance in a stationary position. At this point it is possible to lift off the seat to reposition where you are sitting - without loosing control. Same goes for the feet as you can slide them into different positions on the pedals. As a beginner this is useful as a way of repositioning after just starting off - if you are just not in a comfortable position having mounted the unicycle.
