Ok, I have searched the threads and can’t find an exact answer. I just bought a 2005 torker DX 20". I would like to put a larger tire on it than the 2.125 that it comes with, but without having to replace the rim or anything like that. If I understand correctly, the new DX has a wider frame to accommodate a larger tire. I tried to email Torker but couldn’t. I would like to get a 2.5" trials tire something like the luna. I have read that the 2004 model came with a different size tire than needed for the Luna, but does the '05 come with a different one that might allow for the Luna? Any help is appreciated…(and yes, this is my first posting so thanks for the help).
No, a trials tire would not work, since trials tires fit only on special rims. These rims are designed to be used with the trials tires, and are smaller in diameter. You have one of the larger, true 20 inch rims. It would be too large for a trials tire.
Not to my knowledge. A trials tire is available for the 20 rim, but I’ve never seen one in the US. Me and my friends used to use the Maxxis Max Daddy though, and it was OK at 2.25 (methinks) and knobby.
unicycle.uk.com sells a Onza Sticky Fingers 20"x2.4 Tyre that fits on a normal 20" BMX rim (not the funky 19" trials size rim). I don’t know where you can get it in the US, but it should be available somewhere. I don’t know if that tire will fit in the 2005 20" Torker DX frame.
