#91 |
Kris Holm
Also - please can you measure the width of the bearing housings. They should be 20 mm (not 22 mm).
Is this with a geared hub or regular hub? Last edited by danger_uni; 2012-06-29 at 03:24 PM. |
#92 |
Registered User
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
Kris your revised leg armor is amazing, on long rides I would get some rubbing above my knees from the old version but these new ones with the knee cup are so comfortable I genuinely forget I have them on!
My only concern is they have a fabric cover on the knee area where the old version had the same hard-wearing shiny material as the inside of the calf which makes me wonder how resilient they are? |
#93 |
Kris Holm
Glad you like them!
My personal experience is that the knees get occasionally bashed (when you fall, and not always even then), whereas the inside leg and shins more frequently get hit. I've been testing them for over a year and the knee fabric is still in good shape. |
#94 |
Registered User
Will measure bearing housings in the morning, I have it all packed away now
It is a geared hub, so no spacers Seems the biggest rub is at the weld. I think I can get this to work with a file The bolts are contacting other areas but just scratching the powdercoating I'll take the wheel out and take the whole housing back to bare metal with a flat file ans take some metal off the weld and try again This is my plan for tomorrow Even though the wheel wont turn, it looks amazing |
#95 |
Kris Holm
OK that explains it. It is a tight fit with the geared hub and the slightest variation in spline size or angle on the produced hub affects the lateral position of the cranks, lacking a spacer between them and the bearing.
Kris Last edited by danger_uni; 2012-06-29 at 09:22 PM. |
#96 |
Registered User
So I took the wheel out. I was hoping to just take the edge off the weld. But seems
All 6 bolts were gouging the paint so I filed it all back Now the wheel will spin smoothly. ![]() Until I put the caliper on. Disc is really warped ![]() Hmm guess I'm destined not to ride today I must say however uni is looking Amazing I'm glad I went with the frame rab not the d'brake |
#97 |
Registered User
Love this stuff
Cranks look awesome Was worried about the shifting braking situation but seems to work Took a bit of fettling, but couldn't be happier Thank you Kris |
#98 |
XC Muni
Kris, maybe I missed it, but do you say if your disc brake tab will work with a disc hub, i.e. the Nimbus D' Brake.
__________________
I dream of hamsters and elderberries |
#99 |
Kris Holm
The disk mount on the KH frame won't work for a hub mount disk brake because it's on the right hand side. I haven't personally tried the KH frame with a hub mount disk brake and d'brake on the left side. However, I believe that it works; you'd just have a low profile disk mount on the right side of the frame that wasn't in use. Anyone else on this thread done that?
Kris |
#100 | |
Registered User
Quote:
Cheers, Dan
__________________
Ken Looi - Nostradamus of the unicycle world???
#101 |
Kris Holm
For riders choosing to use a hub mount system, here's a photo of the D'brake on the left side of a KH frame. (photo by Roger Davies).
#102 |
Didier
This is my set up on my KH26 and KH29 with Oracle Nimbus hub, works fine
__________________
http://monocycle.info http://teamcdkmonocycle.blogspot.com/ MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank ![]() my goal : a 3 geared 29" to have only one uni for all kind of rides :-) |
#103 |
Skateboarder to Marine to Unicycler
Just realized that the KH26 I bought this past weekend from Nurse Ben has the D.brake system on the left hand side. This is a 2011 KH frame, but I can verify the setup works well.
__________________
MadFurai's YouTube channel |
#104 |
Unicycles on my mind...
Kris,
It's been a while since I've been on the threads -or a uni for that matter. Thanks for the acknowledgement regarding the initial disc system brought to bear with a useless provisional patent, and sluggish investment. A bit of me still wishes I beat you to market by a year on the crank design, but you were already an established manufacturer and had backing. the crank product would be more costly and heavy than your version... (excellence is the standard you bring) and wouldn't have had a KH logo or Schlumpf endorsement. The ideas were there, like the caliper mount, also available in a less expensive form as the d'brake. Alas, you and UDC are well established and for good reason. Product design and development took far less time than gaining confidence and investment, and the time was mostly spent on the forum developing the market and interest. I guess the focus for Jeff is to maintain conventional / custom unicycle sales as just another internet unicycle shop. Sadly, it seems the vision of competing in components has since dimmed. In hind sight, I wonder if we were really all on board with bringing innovation to the sport from the get go, or just establishing an e-commerce situation. Regardless, kudos dude, and as always, beautifully executed product and design. I am more impressed with your vision as a company than your prowess riding a unicycle -and envious of both! I respect your ability and willingness to take yourself, your company, and the sport to the next level. -Eric J
__________________
Retrofit Disc Brakes to your existing unicycle today! |
#105 |
Registered User
| Tags |
| 2012, announcing, gear, june |
Similar Threads
| When is the new 2012 KH gear coming out??? | Tirving | General Unicycling Discussions | 11 | 2012-02-11 10:06 PM |
| New Fixed-Geared Unicycle Hub! Question for the mountain bike equipment experts | magnustudios | General Unicycling Discussions | 11 | 2012-02-08 12:02 AM |
| Announcing the 2012 KH Factory Team | danger_uni | General Unicycling Discussions | 20 | 2012-01-17 01:29 AM |
| Upgraded and new KH Saddles for May'11 | danger_uni | General Unicycling Discussions | 63 | 2011-08-04 02:03 AM |
| What are the differences between new super mario bros for the wii and mario galaxy fo | Jeremyxuhunter | Unicycling Videos | 8 | 2011-03-28 07:46 AM |
