Unicyclist Community
Reply
Old 2012-06-15, 01:07 AM   #61
DavidHood
Cokering rails2trails asphalt
DavidHood's Avatar
Quote:
Originally Posted by MuniAddict View Post
is 137mm going to be the max?
On my 26" MUni, I will switch from 165 to 137 if I have an opportunity to do some easy XC and don't have my 36er on site. As for the 36er, I'm glad I learned to Schlumpf on 150's but I'm ready to go back to my all time favorite length in 137s. I'm thinking 137mm is going to be the perfect compromise between leverage for high gear and length (shorter) for shifting. Plus, 137s are more practical for 1st gear.
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim
29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride
26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride
DavidHood is online now   Reply With Quote
Old 2012-06-16, 08:29 PM   #62
rogeratunicycledotcom
Mostly OKish Unicyclist
Quote:
Originally Posted by Fatlazypig View Post
The blog entry from UDC uk with the 36 inch schlumpf
Penny that feisty linked to earlier. Shows a shlumpf with prototype new KH cranks and a d brake mount. Looks to be clear that
It can be done. So is it known this is a modified ( belt sanded) mount? Or can it work as is?
Also is it going to be more difficult for left foot upshifters? Or can the d'brake be use on the knurled side?
We did not modify the d'brake at all, it worked as it was meant to, we just fitted 2 washers to position the calliper exactly correctly.
The container arrives on Tuesday and we have schulduled testing the production parts on Wednesday/Thursday with as many combinations as we can. We will put the outcomes on our blog and here.
Roger
__________________
Roger Davies
Unicycle.com in the UK
The UK's Unicycle Source
www.unicycle.uk.com
rogeratunicycledotcom is offline   Reply With Quote
Old 2012-06-16, 09:07 PM   #63
Feisty
Registered User
Feisty's Avatar
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
Sweet
When will the new bits go up on the shop Roger?
Feisty is offline   Reply With Quote
Old 2012-06-16, 09:08 PM   #64
svzurich
Registered User
I've been checking UDC US twice a day for this entire week.
svzurich is offline   Reply With Quote
Old 2012-06-16, 09:11 PM   #65
I think that both US and UK have the containers on the same day. We will get the items on line ASAP. We will try to get some up on Tuesday, but no promises. I would have thought Wednesday is the best we could do in reality...
Roger
__________________
Roger Davies
www.unicycle.uk.com
Old 2012-06-16, 09:35 PM   #66
svzurich
Registered User
Looks like I might just be ordering myself a new KH26 frame and some Spirit cranks. I hope UDC US has compatible disc brake kits on the same day.
Old 2012-06-16, 10:27 PM   #67
Feisty
Registered User
Feisty's Avatar
Quote:
Roger
Sweet Payday on Thursday as well
Old 2012-06-17, 09:13 AM   #68
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
Quote:
Originally Posted by danger_uni View Post
I was wondering about that too, before I started using the setup. It will depend on the rider but it was better than I thought I would be, because you can actually shift, in terms of clicking the button - it just won't engage. Taking the brake off for an instant will let it engage. It takes a bit of time to get used to, but it works fine.
That sounds a bit concerning!
Will it give you a freewheel effect?
GizmoDuck is offline   Reply With Quote
Old 2012-06-17, 02:17 PM   #69
danger_uni
Kris Holm
It never has for me; no problems at all in that regard.
danger_uni is offline   Reply With Quote
Old 2012-06-20, 07:47 PM   #70
Daytripper63
Robs World
I see on UDC the disc brake assemblies they have posted are 160mm rotor I thought the disc set up used a 180 rotor?
Daytripper63 is offline   Reply With Quote
Old 2012-06-20, 08:08 PM   #71
danger_uni
Kris Holm
The Spirit disk cranks are compatible with either 160 mm or 180 mm rotors. Personally I've been using 160 mm rotors.
K.
Old 2012-06-20, 09:50 PM   #72
Daytripper63
Robs World
K.
Thanks
Old 2012-06-21, 12:50 AM   #73
munirocks
money rocks too
munirocks's Avatar
So are the new frames also for both 160 and 180mm discs? Or would 180mm require modifications? I'm still trying to decide what to order, a new frame and cranks seem pretty obvious, but what sizes...
I think maybe a 29er frame would be cool for my 26er and 24er wheels and I'd have the option of adding a 29er wheel later on. But the crank size seems the harder thing to decide. 150/127, 165/137, or 137/110.
I run 140mm Tensiles on my Schlumpf 26er and 36er and I'm satisfied.
But the uphills are pretty tough, which kind of keeps me from ordering 137/110. I know it's only 3mm less but it might make the difference of being able to ride up or walking. So the safer thing would be 150/127 or 165/137 but then 165 seems like overkill to me. So I'll hold off until my mind's made up...
If there were sets of 160/140 or 165/145 or 145/125, or even better triple 160/140/120 or 165/145/125 that's what I'd order.
I'm digging it anyways. Also I appreciate the return to synthetic leather for saddle covers.
__________________
µ-knee
munirocks is offline   Reply With Quote
Old 2012-06-21, 05:57 AM   #74
flycross
Registered User
flycross's Avatar
2Kris : Why is on this picture right crank (ready for rotor) on the left side?
http://www.krisholm.com/khu/images/p...omplete_md.jpg
flycross is offline   Reply With Quote
Old 2012-06-21, 06:53 AM   #75
svzurich
Registered User
When this was brought to Kris' attention earlier, he said the wheel was placed in the frame backwards. He intends for a new picture to be taken to replace that one.
Reply
Tags
cranks, disc, expect
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
When is the new 2012 KH gear coming out??? Tirving General Unicycling Discussions 11 2012-02-11 10:06 PM
What happens when the KH seat gets wet? rpt50 General Unicycling Discussions 3 2011-05-30 02:34 AM
When is the next Capture the moment contest? raymanh General Unicycling Discussions 4 2011-04-25 02:25 PM
What speed should I expect with 4" cranks legtod2 General Unicycling Discussions 18 2008-03-05 01:39 AM
Copyright © 2001-2005 Gilby
Page generated in 0.08873 seconds with 10 queries
