#46 |
Kris Holm
I was wondering about that too, before I started using the setup. It will depend on the rider but it was better than I thought I would be, because you can actually shift, in terms of clicking the button - it just won't engage. Taking the brake off for an instant will let it engage. It takes a bit of time to get used to, but it works fine.
My wife and I are going to UNICON with our baby daughter Nola so it's really more a family holiday. We'll just be there for the first half. To be honest I haven't had much time to ride in the last few weeks since Nola was born, so won't be in the greatest shape but it will still be great to see old friends and meet a bunch of people I've only yet known online. Last edited by danger_uni; 2012-06-11 at 02:32 AM. |
#47 | |
XC Muni
Quote:
![]() I'll admit that I was also suprised, but facts is facts; I even went as far as using a sharpie to write the weights on all the parts; I posted the numbers on the Oracle or Oregon thread. I imagine you could get close with an ultralight, ultra expensive disc brake, but if you want the lightest set up, Maguras are it; unless you can rig up some cantis ![]() Ask Bryce to chime in with some Magura weights, he probably has tons of them lying around...
__________________
I dream of hamsters and elderberries |
#48 |
Seniorenklasse!
mountainuni brake system and kh/ schlumpf hub works (of course florian doesen't recommand it).
really looking forward for stronger (kh) cranks, drops i'm coming back!
__________________
If everything's under control, you're going too slow I trust in those: Triton Mountainuni Brake System Schlumpf |
#49 |
Kris Holm
I've chatted with Florian about this. That discussion related to whether it was OK to use a spacer between the bearing and the crank.
It's really not OK. I did this on an early prototype of my system and started to have issues with the bearings. Unlike an ungeared hub the bearing lacks support on the other side so it creates lateral deformation that's not good for the bearings. However, much of that issue had to do with Sinz cranks, not whether you need a spacer. Based on the fact that people were having spline creep issues, I suspect the Sinz cranks are 6000 series aluminum, which is softer and more prone to this. In contrast, Moment cranks are harder 7075 Al, and the new cranks (more details tomorrow...) are forged from 7050 Al, which is similar to 7075 except with slightly greater resistance to stress corrosion (fracturing). I've not experienced any issue with running this setup with the geared hub, in terms of creep on the splines. The potential issue has more to do with the possibility of slippage of the knurled bearing. As Turtle mentioned, quite a few riders have run the crank-mount system with geared hubs with good success over more than one year of riding, including myself. But as mentioned above, it's possible, so worth noting just in case. Kris |
#50 | |
XC Muni
Quote:
Hey Kris, in reference to Q factor, are the Moments and the KH hub spec'd to the "Shimano" offset, so ~150mm pedal to pedal width? Do you still find this to be an optimal width? The reason I'm asking is that I have been riding your set up (Moments and 100mm hub spacing) since I learned to ride, but have since added an Oregon (125mm hub) with QuAx cranks which are ~175mm in width and now I'm riding the Oregon hub on a 36er with some 175mm Try All cranks which have a more than 200mm in width. I have not noticed any decrease in ride quality, the wider stance is more comfortable and I seem to have more stability, what I notice most is the wider stance has less seat rub/crotch abrasion.
__________________
#51 | |
Mainly XC Muni
Quote:
Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski) "I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule) |
#52 | |
Registered User
Quote:
I used to spend plenty of time hanging around on weight weenie MTB forums where other people weighed their parts and published the info. The argument about rim brakes being lighter than disc brakes was done long ago on there - the only rim brakes which are lighter than the lightest discs are now fancy expensive custom V brakes, standard Shimano offerings are heavier. Maguras have always been known to be heavy, and heavier than even a fairly standard disc brake - hence I don't own one to weigh, so instead I checked out what others had weighed them at http://weightweenies.starbike.com/li...type=rimbrakes - in comparison to user weights for disc brakes at http://weightweenies.starbike.com/li...ype=discbrakes However the weight for Magura rim brakes on there are rather old, hence why I was using published weights - you'll note that I'm using weights for a Magura disc brake, taken from exactly the same Magura website as I got the weight for the HS33. I can't see any reason why their claimed weights for the disc brake should be more optimistic than that for the HS33, and in any case, Magura is known to publish reliable weights (I did a bit of checking, and found some independent weights for the current gen Magura disc brakes which confirm their published specs). In order to be heavier by the amount you claim, the disc brake would have to be roughly twice the published weight! Hence I stand by my comment that a disc brake is actually lighter than a Magura rim brake - reliable numbers supplied. I did a search on here for a post of yours where you provided weights, but all I could find was a previous post where you made a similar claim about how much heavier disc brakes are - maybe you could help me out here, as it should be easier for you to find the post where you gave the numbers, so we can work out why there's such a huge difference in our positions (here's a search for posts of yours containing the word "Magura" for example http://www.unicyclist.com/forums/sea...archid=4511574) |
#53 | ||
Cokering rails2trails asphalt
Quote:
I did a side-by-side test before I sold my Nimbus {disc brake} Impulse 36er. There was very little difference between the disc brake and the rim brake. It should be noted that all my Cokering is done on rails-to-trails asphalt bike paths and rarely in the rain. I waited a long time for UDC to release the 26" Nimbus Oracle so I could have a disc brake on my MUni. It's more of a low maintenance issue for me though I did learn (thanks Brycer) how to reassemble Maggies when UPS damaged my KH36G in transit (thanks Amy for the free replacement). It was not too awfully complicated to get them to work without rubbing. Quote:
Anybody want to buy an unused set of torque wrenches? My mechanical prowess is limited to tightening (with my $50 torque screwdriver) the shift buttons. I need to go to Park Tool school.
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim 29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride 26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride Last edited by DavidHood; 2012-06-14 at 12:39 AM. |
#54 | |
XC Muni
Quote:
But since I did a weigh in already, and saw the numbers, you can be in denial all you want, but the disc brake is heavier whether you like it or not ![]() If you want to make comparisons using the lightest disc brake, then you probably want to be fair and use the lightest hydraulic rim brake... I like the disc brake two reasons: Better function when wet No rim rub Otherwise, they are heavier, more expensive, more complicated, have more issues with squealing, tend to be a pita, and they pull to the side. Last night I upgraded to organic pads on my 26 an 29 to see if I could prevent the glazed pads and the associated squeaking. I'm afraid that I will end up going to a different brake because in the past I had "squeakers" and more often than not it was the brake and not the pad. On a bright note for UDC, their Bengal disc brake has been pretty good to date, but the white color is not for me. I went on Ebay and found a source for Bengal Helix hydraulics in different colors, blue, red, black, gold ![]() I find the best brakes are my legs
__________________
#55 |
just call me similymarco
Right now i also have issues with my Shimano-brake + koolstop semiorganic pads... they scream like hell and the whole uni is vibrating when i pull the brake...
And the braking power is not as good as before (right now it kinda sucks...). The issue occured after my last tour with a very long downhill-section (800 meters in attidude), whole time braking... they got freaking hot...
__________________
Riding for Triton Sponsored by HARTKOR FAKKER Supported by Municycle.com Protected by Better for your body |
#56 |
Kris Holm
Hey all - more info on the new KH Spirit Disk Cranks at krisholm.com (here), and on the new forum thread.
#57 | |
Not "2" Tired
Quote:
#58 |
Kris Holm
Between the 110, 127, 137, 110/127, 110/137, 127/150, and 137/165, that's already a lot of crank models.
Adding the second hole didn't result in major "hot spots" in stress analysis, and it reduces weight. So there didn't seem to be a disadvantage to adding it to all the cranks, even for riders (including myself) that don't typically use the shorter option. The fewer models there are, the better the likelihood is that a KH dealer will actually keep them in stock. So currently I do not have plans to offer a single hole 150 in the disk version. |
#59 | |
Not "2" Tired
Quote:
#60 | |
Registered User
Quote:
Remind me again what the lightest hydraulic rim brake is and how much it weighs (for comparison with numerous light hydraulic disc brakes - eg any 2012 Magura disc, several Formula ones and several Hope ones)? Last edited by aracer; 2012-06-14 at 10:00 PM. |
| Tags |
| cranks, disc, expect |
Similar Threads
| When is the new 2012 KH gear coming out??? | Tirving | General Unicycling Discussions | 11 | 2012-02-11 10:06 PM |
| What happens when the KH seat gets wet? | rpt50 | General Unicycling Discussions | 3 | 2011-05-30 02:34 AM |
| When is the next Capture the moment contest? | raymanh | General Unicycling Discussions | 4 | 2011-04-25 02:25 PM |
| What speed should I expect with 4" cranks | legtod2 | General Unicycling Discussions | 18 | 2008-03-05 01:39 AM |
