Unicyclist Community
Reply
Old 2012-04-27, 02:45 PM   #1
Abysmal Rim
Destroyer of Gravity
Nimbus II vs. KH20 Flatland
Comparing the specs of these two unicycles, I realize that I don't know much about the significance of all the little (possibly large) differences between them. What is it that qualifies the KH20 to cost $600 while the Nimbus II comes in at $225?
Abysmal Rim is offline   Reply With Quote
Old 2012-04-27, 03:41 PM   #2
rpt50
Registered User
The KH models are going to be higher quality for sure, but the critical question is to determine if the quality difference would be meaningful for you.
I will tell you that the Nimbus II is a fine machine, at least based on my experience with the 24" model. I rode mine at least 5 times per week, very often in off road conditions, for 18 months, and the only things that needed replacing were the pedals and tires. The stock pedals suck and should be replaced immediately. Although I have now replaced my nimbus II with a Nimbus Muni for off road, and a 29 for the street, the old II still rides just as well as ever.
rpt50 is offline   Reply With Quote
Old 2012-04-27, 06:50 PM   #3
unihopper
I'd rather be unicycling.
unihopper's Avatar
The biggest differences are the frame, rim and cranks. The KH has an aluminum frame, and the Nimbus has a steel frame. The Nimbus rim is a 32mm freestyle rim, and the KH flatland has the KH Flatand rim, which is 47mm wide like a trials rim but 20" instead of 19". This gives more stability and bounce. Finally, the KH comes with KH Moment cranks, which are indestructable and better for flatland than the QU-AX cranks on the Nimbus. Also, the KH has a higher volume tire and Twisted PC Pedals.
Both unicycles are high quality, but the KH has a few lighter/stronger components and is aimed at flatland unicyclists, whereas the Nimbus is aimed at freestyle unicyclists.
__________________
My Website: www.Unitips.ca for trick tips and gear advice!
Visit Municycle.ca Canada's online unicycle source!
Check out the Municycle.ca Blog for news, tutorials and more!
unihopper is offline   Reply With Quote
Old 2012-04-30, 01:20 AM   #4
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
I would add that the wider, stronger rim is less likely to cause the tire to fold over or come off the rim in large side hops. Unlikely to happen in flatland IMO, maybe in a scetchy landing on a spinning trick. Also you can run the tire at a slightly lower pressure w/o pinch flats (how much?, I'd say </= 5 psi).
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Reply
Tags
flatland, kh20, nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Nimbus II for trials pdpheathcliff General Unicycling Discussions 5 2011-09-30 08:26 PM
NAUCC 2011 Flatland Final Battle. Eli Brill vs. Will Riley gohabsgo333 Unicycling Videos 12 2011-08-02 10:32 PM
Flatland Tire on KH20??? headcamguy General Unicycling Discussions 3 2011-03-27 06:27 PM
Kh vs K1 (Street, trials, flatland, freestyle etc riders only) unicycledood General Unicycling Discussions 9 2011-01-12 04:46 PM
KH20 Flatland uni project danger_uni General Unicycling Discussions 114 2010-05-16 11:31 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07354 seconds with 10 queries
