Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycle Product Reviews
Reply
Old 2012-05-09, 06:24 PM   #46
davidp
Registered User
davidp's Avatar
Quote:
Originally Posted by Nurse Ben View Post
You guys run a ton of pressure, that has got to make for firm riding, max pressure I have ever run was on an RR 2.4 ~ 1.5 BAR, I weigh 86kg.
Don't forget Marco and Feisty are both using a 31mm rim; the 47mm KH rims are 50% wider. That will have a significant effect on usable tire pressures (it's a bigger difference than going from a KH rim to a LM).
davidp is offline   Reply With Quote
Old 2012-05-09, 06:35 PM   #47
Nurse Ben
XC Muni
Nurse Ben's Avatar
Which begs the question: WHY?
I'm thinking of building a "super wheel" for my 26" wth an LM and a Duro 3"
That is the coolest thing about the disc brake set up, I can have more than one wheel and change out for the seasons or use. Still expensive though, so I'm on hold until my 36er is off and running...
Speaking of which, it arrives today, which means big wheel muni this weekend!
__________________
I dream of hamsters and elderberries
Nurse Ben is offline   Reply With Quote
Old 2012-05-09, 07:09 PM   #48
Smilymarco
just call me similymarco
Smilymarco's Avatar
Send a message via ICQ to Smilymarco Send a message via MSN to Smilymarco
Cause if you run a lower preasure theres a bigger possibility that the tire will fold over on angled surfaces or drops.
__________________
Riding for Triton
Sponsored by HARTKOR FAKKER
Supported by Municycle.com
Protected by Better for your body
Smilymarco is offline   Reply With Quote
Old 2012-05-09, 07:16 PM   #49
Feisty
Registered User
Feisty's Avatar
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
Why not?
I believe we both wanted to build a lightweight MUni, I come from riding a ridiculously light Single Speed MTB (it was only 1.5 kg heavier than my KH26 and about the same as my KH24) so was keen to apply some weight weenism to my MUni
The light rim (which I don't think is too narrow) is pretty strong and light and for XC and light MUni rides fantastically and spins up effortlessly so is a dream on the climbs. As I said in the Project thread the Rim Tyre ratio is almost the same as my 3" Duro on a Nimbus MUni rim on my kh24 (same as old KH I believe) and nobody stresses that that is a horrible combination?
I am very new to Uni riding but have two decades in MTB and come from an Engineering background and am a whore for new parts and tech so am not walking into this totally blind. To me the advantage of a light wheel is going to outweigh any stability issues which I am not a good enough rider to notice. I understand the nature of how we ride a single wheel effects a tyre differently to a bike and that ideally a wide rim is better but for me and my skill and type of riding the weight factor is more important.
So far this MUni is everything I could possibly want which is all that matters
At the end of the day it would be boring if we all ran the same setups
Feisty is offline   Reply With Quote
Old 2012-05-13, 04:15 AM   #50
Nurse Ben
XC Muni
Nurse Ben's Avatar
Yeah, but skinny rims look queer
I almost went skinnier, but the KH rims just look so macho, and when I ride a unicycle i just need that little bit of extra ego boost, know what I mean
The only advantage of a wider rim is in maximizing tire volume, but it's not that significant and if I had a second wheel for my 29er I might built up a skinny and run a narrower tire like 2.0
You should try running a Large Marge and a Duro 3", that Unigeezers 24" set up, I tried it on a 26"and it was a big ride and a nice flat profile, so super stable.
__________________
Old 2012-05-13, 06:25 AM   #51
Feisty
Registered User
Feisty's Avatar
By that rationale just call me Seabiscuit
I almost did get a LM on Oracle hub for my KH24 (although with the spoke holes so widely staggered from the center of the rim and the narrow Oracle disk side flange spacing the dish must almost be massive on that combination) but as the cost was almost the same as building a second KH26 which I thought would be better for my type of riding and was interested to see how it would turn out.
A LM setup does look monstrously cool though
Old 2012-05-13, 07:54 PM   #52
JacobSpera
Street
JacobSpera's Avatar
With a wider rim you get a wider tire. This ultimately means that the agility of the unicycle will not be as high. The more muni I ride the more I like to be able to turn on a dime. This allows me to be able to ride super steep trails with lots of turns and technical terrain. Also you can find a lot stronger and lighter rims, unicycle rims seem to gone to shit with how strong they are. You constantly have to baby them so they can stay true. Nothing is wrong with higher pressure I say, you get less tire fold and its easy to roll and go fast. I find that speed is a lot better for getting over things than anything else.
__________________
Team MAD4ONE
JacobSpera is offline   Reply With Quote
Old 2012-06-07, 11:46 PM   #53
Jake95
Registered User
So, when removing/installing the wheel, is there anything special you need to do with the disc brake? Like move or adjust?
Jake95 is offline   Reply With Quote
Old 2012-06-08, 07:56 AM   #54
bouin-bouin
Didier
bouin-bouin's Avatar
Quote:
nothing, disc is on the hub and D-brake is fixed on the bearing which is on the hub
__________________
http://monocycle.info
http://teamcdkmonocycle.blogspot.com/
MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Old 2012-06-08, 06:30 PM   #55
Jake95
Registered User
so, put taking the wheel on and off is just like a uni without a d-break?
Old 2012-06-08, 09:23 PM   #56
bouin-bouin
Didier
Yes, almost same; D-Brake needs some small caution while tightening.
As it's planned for different frames (Nimbus, KH, QX, ...), holes for bolts are oval, so needs first to find the right position by approaching the bolds and then needs to tighten first the bold on caliper fixations side; but this is not a big issue. I use blue Loctite glue to secure bolts tightening
__________________
Old 2012-06-13, 05:18 PM   #57
jbtilley
Muni Foot
jbtilley's Avatar
I think I may have missed an important detail somewhere along the way.
One thing confused me a bit about the Oracle (and other disc break related threads). It almost sounded as if the day had finally arrived where people could get disc breaks for their unis. Couldn't help but think... but the Impulse already has a disc break.
So is the Oracle a first in the sense that disc breaks are now available on smaller wheels or first in the sense that the break is much improved over the model featured on the Impulse?
Maybe I misread the whole thing and the anticipation was over the arrival of new stock and not necessarily due to the arrival of something totally new - with respect to breaks. I recognize that the Oracle with the new frame et al is something totally new.
Just trying to see if I missed a detail where a newer, better model of disc break has become available.
jbtilley is offline   Reply With Quote
Old 2012-06-13, 05:27 PM   #58
Feisty
Registered User
Feisty's Avatar
This is the first standard 100mm disc hub width the Oregon and Impulse were non standard 125mm so not retrofit-able to peoples existing frame.
I got mine the month the Hub was released and it is awesome
Old 2012-06-13, 06:34 PM   #59
jbtilley
Muni Foot
jbtilley's Avatar
Ah. Thanks for the info.
Old 2012-06-13, 08:55 PM   #60
DavidHood
Cokering rails2trails asphalt
DavidHood's Avatar
Quote:
Having owned an Impulse (swapped to a geared 36er) I knew the disc brake was for me so I waited until the Oracle was released (almost bit on the Oregon, glad I didn't) before I got into MUni. Then again, I buy whole kits and don't customize much. Because, as Fiesty said, the real BIG deal was the release of the Oracle hub which could be retrofitted on other mountain unicycles.
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim
29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride
26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride
DavidHood is offline   Reply With Quote
Reply
Tags
brake, disc, disc brake, muni, nimbus, oracle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
disc brake or hydrolic brake? Municrazy15 Unicycle Product Reviews 18 2012-08-21 11:39 AM
[For Sale: North America] Nimbus (disc brake) Impulse 36er DavidHood Trading Post 6 2012-04-11 03:13 PM
disc brake or hydrolic brake? Municrazy15 General Unicycling Discussions 12 2012-03-13 04:25 PM
Disc brake adaptors joemarshall General Unicycling Discussions 21 2004-01-22 09:48 PM
Muniac Manor - Building a MUni (Part II Disc Brake On) Scott Bridgman General Unicycling Discussions 0 2000-01-02 03:55 PM
Copyright © 2001-2005 Gilby
You Rated this Thread:
Page generated in 0.11734 seconds with 11 queries
