#1 |
Registered User
Leaky Shlumpf Hub
Just bought a shlumpf hub from a user here. I just cleaned it up a bit and put some new chain oil in it. I woke up this morning and there was oil leaking from the hub to a point there was a puddle below the unicycle.
I do not know much about the shlumpf product other than what I have read on the KH manuals and shlumpf website. I anyone knows what would causes this and if/how I could fix it that would be great. |
#2 |
muni commuter
Probably not a problem with the hub, they're not totally sealed and will leak some, more in higher temperatures and/or with low viscosity oil. There are a few Schlumpf hub discussion threads you might check out:
Schlumpf hubs: general discussion. Schlumpf hub setup discussion thread Schlumpf hub servicing Schlumpf oil You can also get more of the grease that Schlumpf uses.
__________________
My 29er is my little wheel. Roll it, baby! pLs forgve anu typist imak win positing forum my fone. |
#3 |
is what it is
Not a Schlumpf owner, but just using simple logic... this could be a sign that you've filled the gearbox beyond capacity.
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell |
#4 | |
Treehouse Muni Rider
Quote:
corbin |
#5 |
Not "2" Tired
You probably over-filled it. As Florian has said, they will leak to some extent, but if there's just too much lube in the hub, it will come out a lot more then usual, which should be gradual and minimal.
#6 |
Registered User
cool thanks I did not know they could be overfilled honestly. well hopefully no damage done and Ive just got a greasy mess to deal with for a few days.
#7 |
The other unicycling geologist.
Bacon-riffic
I hear bacon grease is a prime candidate.... hahahahaha.
__________________
Ken Looi - Nostradamus of the unicycle world???
#8 |
show me the muni!
Centrifugal and gravitational force will pull regular oil off the gears and out to the hub body, where it won't do any good. If your hub is truly overfilled with oil, and it eventually stops leaking, does that mean it now contains the proper amount of lubrication... or none?!!
Oil and grease are different.Some greases are formulated to make them stick to the surfaces they lubricate. Schlumpf Innovations chose a grease with these properties. Even still, I bet every Schlumpf hub owner wonders how much grease is actually in their hub and when to add more. It's a bit of black magic. The easiest unknown to remove from the equation is the quality and properties of the grease you're using. I've tried to create a cheap easy way for Schlumpf hub owners to purchase the right grease. I encourage every Schlumpf hub owner to take advantage of it. |
| Tags |
| guni, hub, leaky, problems, shlumpf |
Similar Threads
| Shoes for shlumpf shifting | Fatlazypig | General Unicycling Discussions | 10 | 2012-01-18 06:12 AM |
| Hub question | discuni | General Unicycling Discussions | 4 | 2011-05-22 05:43 AM |
| Qu-Ax Debut Frame on KH hub/Nimbus Hub | emile | General Unicycling Discussions | 4 | 2011-05-09 11:39 PM |
| A Perfect Shlumpf Ride | critter | General Unicycling Discussions | 1 | 2008-06-27 03:15 PM |
| WANTED: ISIS Hub (you lucky ones upgrading to the KH/Shlumpf must have something) | Brian O. | Trading Post | 15 | 2008-03-01 01:41 AM |
