Unicyclist Community
Reply
Old 2012-03-06, 06:04 PM   #1
UniVNG
Registered User
New Quax disc brake frame
I've seen this on FB.
It seems that all brands are going to release disc brake products this year!
What do you think about this design? Nimbus one seems lighter.
UniVNG is offline   Reply With Quote
Old 2012-03-06, 06:22 PM   #2
scotthue
10k & Marathon World Champ
scotthue's Avatar
Send a message via Skype™ to scotthue
More photos and larger version of above photo:
scotthue is offline   Reply With Quote
Old 2012-03-06, 07:49 PM   #3
brycer1968
Brycer1968
brycer1968's Avatar
I do like the look of that brake rotor with the saw blade teeth. It doesn't look very leg-friendly tho.
A question: do the uni disk riders feel like they end up coming into contact with the brake rotor much? Do your brake rotors get bent on stuff during UPDs? Does it make a difference between inboard or outboard disks?
__________________
Brycer1968,
Mayhem on one-wheel since 1968
brycer1968 is offline   Reply With Quote
Old 2012-03-06, 08:32 PM   #4
turtle
Seniorenklasse!
turtle's Avatar
i use the mountainuni system, outside of course and ride all the technical stuff with it, not sure if i get in contact with the rotor, because i wear high boot, but it's no problem. sometimes the rotor bend a little bit, but i can get it straight with the hands easily... i think it's not necessary to be inside at all...
__________________
If everything's under control, you're going too slow
I trust in those:
Triton
Mountainuni Brake System
Schlumpf
turtle is offline   Reply With Quote
Old 2012-03-06, 08:38 PM   #5
Nurse Ben
XC Muni
Nurse Ben's Avatar
Never used outboard.
Never hit my leg or foot on the disc, it's just set into the frame too far and it's not all that big, I'm far more likely to stick my foot in the spokes; fortunately I don't have that problem either
The worst thing my rotor has hit would be a branch as I ride by a down tree or some bushes.
Honestly, the disc brake is far more protected than my Magura calipers, which have struck rocks on UPDs.
So Bryce, are you going to start importaing Magura disc brakes? Do you have much info on them, like which is more durable, etc... If you had disc brakes, I'd think you would get an influx of brake orders when the Nimbus hub is released.
Nurse Ben is offline   Reply With Quote
Old 2012-03-06, 11:47 PM   #6
aracer
Registered User
Quote:
Originally Posted by scotthue View Post
Also looks like another 100mm disk hub.
aracer is offline   Reply With Quote
Old 2012-03-06, 11:56 PM   #7
brycer1968
Brycer1968
brycer1968's Avatar
Quote:
The only discs I have here are the older raceline colored Gustavs from the 1990's.. They are big and powerful for downhill/freeride use, but total overkill for unicycling.
Because rim brakes only require maggie four bolt mounts on the frame (and don't require a dished wheel and disc hub or special outboard crank and spider set up), I think there will always be uni riders wanting old school rim brakes . . . .
Brycer
__________________
Brycer1968,
Old 2012-03-07, 02:41 AM   #8
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
looks good, I like the look of the hub. Looks like 48 spokes, great for 32 spoke builds
__________________
saskatchewanian is offline   Reply With Quote
Old 2012-03-08, 02:28 PM   #9
Nurse Ben
XC Muni
Nurse Ben's Avatar
Yup, and 100mm spacing, could be a nice hub.
The caliper mount is a bit "monsterous" looking, lots of metal, maybe that's the prototype?
Old 2012-03-08, 02:50 PM   #10
bouin-bouin
Didier
bouin-bouin's Avatar
No, prototype was worse ....
__________________
http://monocycle.info
http://teamcdkmonocycle.blogspot.com/
MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Old 2012-03-09, 03:19 AM   #11
knoxuni
wes style!!
knoxuni's Avatar
Send a message via Skype™ to knoxuni
Oh my.... that is a scary prototype!
__________________
Be a dumbass
experience dumbass consequences
its full circle of dumbass
And then, do it again. That makes it an infinite loop!
knoxuni is offline   Reply With Quote
Reply
Tags
brake, disc, frame, quax
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hydraulic Rim and Disc Brake Reviews Nurse Ben Unicycle Product Reviews 7 2012-01-03 09:38 PM
disc brake on kh36 BigWheelTex General Unicycling Discussions 3 2010-11-23 06:06 AM
photo of disc brake on Coker please! leadpan General Unicycling Discussions 5 2005-11-11 07:06 AM
Disc brake adaptors joemarshall General Unicycling Discussions 21 2004-01-22 09:48 PM
Disc Brake Pictures Chris Reeder General Unicycling Discussions 0 2000-04-01 07:10 AM
Copyright © 2001-2005 Gilby
Page generated in 0.08472 seconds with 11 queries
