Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Registered User
I had a few minutes this morning and the weather was clear so I gave my new 36" a try. Largest I had riden before was a 24". I went about 50 feet then over the front I went. It wasn't pretty, I am fine , but I sure wish I had a video of it. What surprised me was how much time I had before I hit the ground. Man that thing is tall. I tried again and had another UPD over the front.
UPD's off the back I can handle. How can I get better at UPD's over the front so I don't land hands first? I have a Nimbus Impulse with 150mm cranks. Last edited by zeus661; 2012-03-03 at 07:52 PM. |
#2 |
36er <3
My best advice as far as having an UPD off the front of a 36er (or any unicycle for that matter), is to let the unicycle take the fall, and when you are going fast, just try to run it out as best you can.
Have fun with the big wheel.
__________________
"Why'd you put your beer down for this photograph?" -maestro8 "I will irradiate my gonads in the name of unicycle science." -GizmoDuck |
#3 |
Registered User
For some reason I don't feel like I was fast enough to get to my feet. And part of it is not wanting my new $1000 toy hitting the ground.
#4 | |
Unicycle Advocate
Quote:
If you are worried about an expensive handle being broken, leave the bar ends slightly loose- firm enough to hold onto but they will move in a crash. My KH T-bar handle snapped but only after a couple of years of riding and crashing and letting people use my unicycle. I tell non-riders not to hold the handle when attempting to mount my 36" but they usually don't listen and yank on it. Start doing some intentional dismounts off the front so that when it happens unexpectedly your reflexes will hopefully kick in and you will land safely. Being the captain of a sinking ship (unicycle) and going down with it is worse than an UPD it is a crash! UPD is where you land on your feet- un-planned-dismount. Last edited by Rowan; 2012-03-03 at 09:16 PM. |
#5 |
Jeff Hanson
I know where you are coming from. I hurt my wrist really bad teaching myself to mount mine.
Are you using the handle bars? I would say not too until you need them. Knowing that you're going to dismount helps so you can get off sooner instead of waiting till the last second. Like you said, it can seem like a long time, espessially if you are going slow. I also think trying not to dismount too slowly is good or you could tip to the side, which is much worse than front or back when you get tangled. Getting off right away means not holding onto the handle till it is already underneath you. This means you have to trust your $1000 investment was worth it and that at worst you will only scratch the pedals and seat bumpers a bit. Holding onto the hadle bars is much worse than the seat, so again just leave them off till you need them. |
#6 |
Jeff Hanson
Just noticed your post about handlebar length, so yeah I would reccomend to wait till you are able to ride a good distance before even putting them on. Then see what feels right.
#7 |
Registered User
I agree with the previous advice:
Ditch the handlebar to start with. it will just get in the way. Be prepared to hop off the unicycle in case of a problem. Do NOT go down with the ship! Unicycles are made to fall--don't baby it. ![]() Wear wrist guards! Good luck! Scott |
#8 |
Registered User
I just started riding a 36in. uni. Keeping your butt/hips firmly on the seat will really help not going over the front. I visualize this. I might lean my upper body forward but I make sure my hips/butt is right over the wheel and is not tilted forward. My two cents worth.
#9 |
Not "2" Tired
I would highly suggest forearm/elbow and also wrist guards. Also make sure your saddle isn't too high, which can make it more difficult to fall clear of the uni, and not get the saddle caught between your legs!
#10 |
Registered User
I was praticing mounting and dismounting (without pedaling) and notice that it appears my shoes seem to stick to the pedals to much. My previous uni had pedals that were just rubber on both side. This uni has the studs that stick up and seem to hold my shoes longer. I think if I can get my feet off the pedals a few nano seconds faster my UPD's would be a little better. Anyone else feel that?
#11 | |
36er <3
Quote:
__________________
#12 |
Registered User
I was looking at the pedals and could use some help on how the steel pins come off. I do not want to damage anything removing them.
#13 |
Registered User
#14 |
...feeding the machine...
The pins usually accept a small hex wrench. Also, I second the wrist-guards suggestion, and knee-pads.
__________________
steveyo ...like having your own personal rollercoaster... - a few uni race write-ups - muni and kokopelli uni t-shirts, mugs and stickers |
#15 |
XC Muni
Drop the seat, remove the bars, put on some pads, don't worry about the uni hitting the ground, and learn how to get off the uni:
Falling backwards is baaaad, you have less balance backwards and you are more likely to hurt your back, neck, and head. Falling forwards is better because you can run out of your fall and or roll. Getting off a uni is easy, just jump! You can use the pedals and seat as a means to propel yourself off the uni, this "platform" lets you stabalize yourself as you UPD, but you need to let go of the uni and let it crash. It won't hurt the uni, you can replace the bumper and pedals if they get scratched. The handle is not necessary for learning to ride a 36er, just use the seat grab until you become more stable. Drop the seat so you don't feel so far off the ground. |
| Tags |
| first attempt on my 36, front, upd |
Similar Threads
| First time on 36 in unicycle | madams | General Unicycling Discussions | 2 | 2012-01-01 03:06 PM |
| Bent my seatpost on my 20" trials. Advice on choices? | Dane M | General Unicycling Discussions | 10 | 2011-08-05 06:42 PM |
| My first 36? | Ecaz | General Unicycling Discussions | 1 | 2011-06-14 02:08 AM |
| My first 20" training | kamikaze | General Unicycling Discussions | 0 | 2011-05-07 09:16 AM |
| I survived a spill on my 36 | tanny | General Unicycling Discussions | 20 | 2011-04-20 11:08 PM |
