Unicyclist Community
Reply
Old 2012-02-19, 11:47 PM   #1
zeus661
Registered User
Quick release pedals?
I remember seeing somewhere in the forums a type of pedeal adapter that made it possible to change the pedals on a two hole crank without a wrench. You screwed the thingy's in to the crank then the pedals would lock into them. Anyone know where to find them? I link would be great.
Thanks, Mark
zeus661 is offline   Reply With Quote
Old 2012-02-20, 02:35 AM   #2
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Did you use the search?
http://www.unicyclist.com/forums/showthread.php?t=85849
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2012-02-20, 01:35 PM   #3
Nurse Ben
XC Muni
Nurse Ben's Avatar
http://www.ebay.com/itm/XPEDO-XCF-06...-/230664980571
http://www.ebay.com/itm/Wellgo-Quick...item43ad712242
http://www.ebay.com/itm/Xpedo-295g-T...item7dbd0f5883
They all seem to have a little more off set due to the addition of a QR mechanism. The bear trap XCF and the Traverse styles are far nicer than the older road style pedals shown in the previous threads.
I was thinking about this very thing the other day when contemplating whether a dual hole crank really made sense; due to the time factor in changing pedal positions, I don't tend to change pedals on a ride, which is really the only advantage of having a two hole crank.
Keep in mind that the additional QR is ~$35 and is not included with the pedals.
Nurse Ben is offline   Reply With Quote
Old 2012-02-20, 04:32 PM   #4
bouin-bouin
Didier
bouin-bouin's Avatar
and not compatible for 110/127mm cranck as not enough space, just compatible for 125/150 and 137/165
__________________
http://monocycle.info
http://teamcdkmonocycle.blogspot.com/
MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Old 2012-02-20, 06:50 PM   #5
Nurse Ben
XC Muni
Nurse Ben's Avatar
Those Bear Trap styled pedals look nice and the second hole in a set of 150/125 would be no problem by the looks of them. My hesitation is $$ and durability. I suppose if they fail you can warranty the pedals, but that's not really a very good answer.
I'm going to check on MTBR and see if there are any reviews.
Old 2012-02-20, 11:40 PM   #6
ImFalling
Graham
What do you need quick release pedals for? A small set of allen keys costs $5-$10 and fits in your pocket. Who needs a pedal spanner?
ImFalling is offline   Reply With Quote
Old 2012-02-21, 01:09 PM   #7
Nurse Ben
XC Muni
Nurse Ben's Avatar
In terms of fiddle time, wearing out threads, and just being a general pain the arse, changing pedals on the trail sucks. I'd be willing to bet that most people who ride dual hole cranks rarely change the pedal position on the trail.
Imagine being able to stop, press a button, and simply switch the pedal from one position to another in seconds. I would do this on the trail, whereas with having to take off my pack, get out a tool, unscrew the pedals, screw the pedals back in, put the tool away, put the pack back on, well it's easy to see why folks don't change their pedals on the trail.
I want pedal position changes to be as easy as lowering or raising my seat, which I do with a quick release clamp
My only question is durability, cuz $100 investment is a lot of the pedals wear out in three months. Xpedo seems to make good pedals.
Old 2012-02-21, 01:32 PM   #8
zeus661
Registered User
Exactly my thoughts. I was thinking of putting them on a 36".
Old 2012-02-21, 02:25 PM   #9
Nurse Ben
XC Muni
Nurse Ben's Avatar
I am about to pull the trigger on those bear traps and a second set of QR fittings, just need to pick a color; I like the gold, but black is nice
These are going on my 26Guni 125/150 Moments, though, I suppose I could put them on the 29er if I had two additional sets of fittings...
Anyone have a source for the fittings for less that $35 a set?
Old 2012-02-21, 05:03 PM   #10
Feisty
Registered User
Feisty's Avatar
Location: Worthing, England Unicycle 1: KH20 LN Sold Unicycle 2: KH24 (HS33) Sold Unicycle 3: 24 Impact Gravity Unicycle 4: KH26 (Disc) rebuilt Unicycle 5: KH29 (Disc) Unicycle 6: Triton 36 (Disc)
How do you fit two adapters of these type though? Looking at them doesn't the large side button rotate when they are screwed in so you could never get two next to each other, the other type linked to further up the thread has a push in collar so can be put side by side.
I would hate for you to waste your cash!
Feisty is offline   Reply With Quote
Old 2012-02-21, 05:22 PM   #11
Nurse Ben
XC Muni
Nurse Ben's Avatar
Yup, it's gonna be tight, and I have not found a source for these pedals other than Taiwan, which would make a return problematic.
Old 2012-02-21, 06:28 PM   #12
Feisty
Registered User
Feisty's Avatar
I guess you have already taken rough measurements from the pictures as you know the diameter of the threaded section so could calculate the other dimensions?
It would be good to have them built into the crank but then we are back to the small Uni market (and the a subsection of that to boot), damn economies of scale!
Reply
Tags
pedals, quick, release
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Quick release pedals skilewis74 General Unicycling Discussions 9 2011-03-15 09:06 PM
Quick release for a kh 24. JosephCampbell General Unicycling Discussions 12 2007-08-01 09:17 AM
Hope Quick Release vivalargo General Unicycling Discussions 0 2007-02-17 04:47 PM
Quick Release? DJack General Unicycling Discussions 8 2006-09-08 01:32 AM
Quick Release Graham W. Boyes - TOAO.ne General Unicycling Discussions 6 2001-06-25 08:30 PM
Copyright © 2001-2005 Gilby
Page generated in 0.08279 seconds with 10 queries
