#1 |
Registered User
Tool fit or not
Sometimes I don't know which sub-forum to post a topic in, this is an example.
It seems like RSU is a catch-all, so here it is. Here is a cheap crank puller: http://www.ebay.com/itm/350483658583...84.m1497.l2649 Can anyone tell if this will work on a square-taper hub, e.g. the original Coker? I compare this to similar Park tool and the ends look different, that's why I ask. Last edited by wanderling; 2012-01-22 at 10:45 PM. |
#2 |
Registered User
Yes, this one is for square-taper.
#3 |
ERIC P
The extractor part should work... but I don't get how you would use the handle/wrench without taking the thing apart first.
__________________
My friends, love is better than anger. Hope is better than fear. Optimism is better than despair. So let us be loving, hopeful and optimistic. And we’ll change the world. - Jack Layton |
#4 | |
Registered User
Quote:
I have this particular extractor and cannot (for the love of God) figure it out. So I remove the screw, put the black part into the crank, and turn the silver part towards (into) the hub and it'll push the crank apart? Feeling pretty dumb here; someone with more mechanical talent please let me stand on your shoulders. |
#5 | |
Registered User
Quote:
). Just do it until it pulls the crank off, than remove the puller from the crank.
#6 | |
Registered User
Quote:
So the silver part pushes the crank off the hub? I must not be turning hard enough then. The handle is less than ideal because it cuts into your hand when pushing or pulling hard. Last edited by wanderling; 2012-01-23 at 12:46 AM. |
#7 |
Registered User
Found answer by semach.the.monkey in this thread:http://www.unicyclist.com/forums/showthread.php?t=79348
Will try when home (this time with socket wrench). |
#8 |
North Shore ridin'
The important part is to make sure you get as many of the threads on that black part in there before screwing in the silver part. You want lots of grip so you don't damage the threads. You could toss the handle that came with it and just use any old wrench that fits the hex part. The pullers I use are essentially just the black & silver part of yours.
__________________
John Foss "jfoss" at "unicycling.com" www.unicycling.com "Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben |
#9 |
Registered Unicyclist
Also make sure you've removed any washers so it is pushing directly on the end of the axle.
| Tags |
| fit, tool |
Similar Threads
| Why am I not faster with shorter cranks? (Oh no, not crank length again...) | Twente Muni | General Unicycling Discussions | 26 | 2012-01-10 08:25 AM |
| To Build UW or not to Build UW? | jhoyt888 | General Unicycling Discussions | 26 | 2011-07-08 04:05 AM |
| [Wanted North America] 29-inch trainter or Nimbus (or equivalent) | Darth Elevator | Trading Post | 4 | 2011-06-16 04:31 PM |
| brakes or no brakes on your 29 or 36 in | madams | General Unicycling Discussions | 16 | 2011-06-14 10:50 PM |
| does this fit? | wouter | General Unicycling Discussions | 4 | 2011-05-16 06:58 PM |
