Unicyclist Community
Reply
Old 2012-01-10, 12:59 PM   #1
danielx129
Registered User
Talking What I the best unicycle for beginners?
I want to start riding unicycles and I want to know a good one thats also cheap and good for doing tricks
danielx129 is offline   Reply With Quote
Old 2012-01-10, 05:08 PM   #2
theUNITY
Uni or Die.
Quote:
Honestly, ive had my Torker lx for years, it has held up great, for a beginner it will be great. They are about $140 New. People will tell you you need a kris holm with upgraded everything. But that's just ridiculous at $600. Even though im sure i will own one myself eventually....
__________________
Uni or Die.
theUNITY is offline   Reply With Quote
Old 2012-01-10, 09:36 PM   #3
danielx129
Registered User
Thanks for the info. Is this a good uni:
Also, what is a good wheel size for doing tricks?
Old 2012-01-11, 12:58 AM   #4
MadFurai
Skateboarder to Marine to Unicycler
MadFurai's Avatar
I started out on an Avenir DLX that I got from Amazon for about $70 bucks. I bought it a year ago and it is still serving me well. It is a great trainer that is easy to learn on. I have hopped on it, ridden off curbs with it, learned how to idle with it, learned how to ride "seat out" with it, etc. Even though I now have 3 unicycles, I still think it was the perfect choice for a beginner. Once you get good enough to where you are ready to experiment with tricks or MUNI, then you'll know more about what you need for your next UNI. When learning the basics of riding, there is no reason you need a $300 or $600 UNI in my opinion.
__________________
MadFurai's YouTube channel
MadFurai is offline   Reply With Quote
Old 2012-01-11, 12:59 AM   #5
MadFurai
MadFurai's Avatar
As for the size, I would definitely start out on a 20 inch for learning.
__________________
Old 2012-01-11, 08:21 AM   #6
Byc
Registered User
I'd say 20" is the right size to start with.
It doesn't have to be expensive, but don't go to cheap. An uncomfortable saddle for example can slow down progress a lot.
Greetings
Byc
Byc is offline   Reply With Quote
Old 2012-01-11, 02:02 PM   #7
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Looks like a decent uni for learning. Since it doesn't have a handle, light trials and some tricks will be a little harder.
I wouldn't do lots of hopping or down much more than a curb.
20 is the better for tricks and light trials, 24 would be better for cruising and light Muni.
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2012-01-11, 11:54 PM   #8
aracer
Registered User
My first uni was a lot cheaper than that - £30 (about $50) from Lidl (a discount supermarket). Still going strong, and I use it to do a lot of practice and learning new stuff - plenty of hopping! Depends what you mean by tricks - if you can't yet ride, then I presume you don't have anything too radical planned. Just buy cheap and when you get into it you'll get more idea of what you really want. I don't regret for a moment getting one so cheap - seriously thinking about getting a proper hardcore 20" (19"?) machine to replace it, but then I might never have ever tried if I'd had to spend lots of money to start.
aracer is offline   Reply With Quote
Old 2012-01-12, 02:47 PM   #9
MP Uni
UnRegistered User
MP Uni's Avatar
Yeah I have the Torker LX and it's a beast. I've put it through many light trials and a couple considerable drops and its still goin strong. I saw the 2012 model on Amazon for $109
__________________
It's called a Muni ride, not a Muni walk ... If you're not tired at the end of a MUni ride, you're doing something wrong. - Tholub -
Unicycles: 19" Koxx One Black Domina II, 29" Nimbus Drak equipped with custom center-pull brake system
MP Uni is offline   Reply With Quote
Old 2012-01-12, 04:08 PM   #10
kamikaze
Fallen Rider
kamikaze's Avatar
Send a message via ICQ to kamikaze Send a message via AIM to kamikaze Send a message via MSN to kamikaze Send a message via Yahoo to kamikaze Send a message via Skype™ to kamikaze
I'd say that Avenir thing is too expensive for a beginner unicycle and too cheap for anything advanced. You won't get a decent rim for that price and I wouldn't trust the saddle or the cranks either.
Get a decent Freestyle starter uni, that'll be cheaper and won't promise you things it cannot deliver.
__________________
[ Karlsruhe/Germany - kamikaze@bsdforen.de ]
Grizoo: Wowwww! you guys should get a uni or something !!!!!
kamikaze is offline   Reply With Quote
Old 2012-01-13, 12:06 AM   #11
wheel bubble
Registered User
C'mon Folks
I am surprised that no one asked the weight of the individual looking to begin unicycling. This may be the most important factor. Sure cheaper unicycles are great in general to learn on if you are more on the lighter side but, if you're a little on the heavier side then you may not have it long enough to do much of anything; even learn on it. Slightly pricier uni's will usually have the added strength (needed even for a beginner) because of his or her weight. The frames will have better welding, stronger cranks, hubs, double walled rims etc. One may want to consider this when buying even a "learner" unicycle. Also I might add, there is an advantage to being a tad on the heavier side, in that taking the route of a pricier unicycle for the added support and SAFETY issues, you won't need to waste more money upgrading later when you become hooked. You will become hooked.
wheel bubble is offline   Reply With Quote
Old 2012-01-13, 12:46 AM   #12
aracer
Registered User
Quote:
We're the choir on here. You have to acknowledge the possibility that somebody buying a uni might give up before working out how to ride (one of the reasons I was reluctant to spend too much - I had to buy my own because mrs aracer refused to get me one as a present because it would never get used).
Old 2012-01-13, 01:17 AM   #13
danielx129
Registered User
thank you every one for these answers really helpful. im getting the avenir deluxe 24 inch!
Old 2012-01-13, 01:36 AM   #14
wheel bubble
Registered User
I hear that aracer. My suggestion was not for everyone though. Yes, ideally an inexpensive route for a beginner can be a good start. I was just making a point for heavier people. Unfortunately for them, cheaper means there will be a lesser weight capacity that it will support which can be dangerous even while learning. So the bigger folk may need to go pricier for the strength that a more quality build would provide. You will lose interest no matter what if the Uni bends,cracks, or breaks before you even get cruising.
Old 2012-01-13, 01:40 AM   #15
wheel bubble
Registered User
Can I hear the choir sing? we are the choir...
Reply
Tags
beginners, maestro1247352, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What is the Best Municycle Tyre going??? MrChoomii General Unicycling Discussions 26 2012-11-25 01:47 AM
I'm curious.... What is the best make of Muni?? MrChoomii General Unicycling Discussions 29 2011-08-04 09:01 AM
Giraffe Unicycle for Travel - whats the best fooloffun General Unicycling Discussions 4 2011-04-20 08:31 PM
What are the differences between new super mario bros for the wii and mario galaxy fo Jeremyxuhunter Unicycling Videos 8 2011-03-28 07:46 AM
Copyright © 2001-2005 Gilby
Page generated in 0.11627 seconds with 11 queries
