Unicyclist Community
Go Back   Unicyclist Community > Non-unicycling Discussion > Just Conversation & Introduce Yourself
Reply
Old 2011-12-06, 03:38 PM   #1
Peace Frog
Registered User
Bent Giraffe Frame
Hello there guys, this sunday a friend of mine landed on my giraffe's (Qu-Ax Giraffe) frame and bent it unfortunetaly. What i'm curious about is that is it possible to straighten it without damaging it, or do i need a new frame ?
The thing is i bought it from Austria and i live in Turkey, which makes it difficult for me to send it to the store (or Qu-Ax's itself)
It's been only 3 weeks and i'm really frustrated about it, sorry for the bad quality of the photos but, it'll give you an opinion about it.
Peace Frog is offline   Reply With Quote
Old 2011-12-06, 05:48 PM   #2
bungeejoe
J Myers
bungeejoe's Avatar
I have
I bent my giraffe worse than yours. I managed to straighten it and have used it successfully for lots of ridding since.
JM
__________________
Bellingham Muni Weekend June 7, 8, & 9, 2013
bungeejoe is offline   Reply With Quote
Old 2011-12-06, 07:19 PM   #3
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
Put down some wooden blocks fairly far apart and place the frame ontop so the bend is up. Gently bounce on the frame until it is strait again.
The great thing about steel is it can bend/unbend a little bit without loosing much strength.
__________________
saskatchewanian is offline   Reply With Quote
Old 2011-12-06, 09:50 PM   #4
maestro8
is what it is
maestro8's Avatar
Quote:
Originally Posted by bungeejoe View Post
ridding
Quote:
Originally Posted by saskatchewanian View Post
loosing
This forem is macking me dummer.
Unicyklists I hate yoo!
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2011-12-07, 06:35 AM   #5
Peace Frog
Registered User
"Losing without much" Exactly my point, i'm not going to use "Brute Force" on as the frame would only get worse. Is there any tools or any other stuff that could help me such as heating it etc ?
Old 2011-12-07, 08:10 PM   #6
faceplanter
pensioneer
faceplanter's Avatar
I’m with saskatchewanian.
He did say ‘gently’ and his method is spot on IMHO. The lower, double tube, part of the frame will be stiffer so no worries there. Heat? Noooooooo, Wrecked chrome and local distortion of the tube. If you don’t like the sound of wooden blocks use sandbags which will conform to the tubes and help to stop it rolling over.
__________________
Every day without a plant-a bonus.
Do Re Me So Far So Good - (Carter USM )
faceplanter is offline   Reply With Quote
Old 2011-12-08, 04:53 AM   #7
johnfoss
North Shore ridin'
johnfoss's Avatar
To take it to the next level, get it reinforced. Or do a manual bend-back and wait until it happens again. Those frames aren't particularly strong, and that's where giraffe frames usually bend or fail.
So if it does break or get worse, have a bike shop or welder repair it with some reinforcement. Gussets (front, back and both sides) or just thicker tubing from the bottom bracket upward, at least 20 cm or so.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2011-12-08, 03:36 PM   #8
UniBrier
Time To Ride
UniBrier's Avatar
Huh? and nuthing aboot poasting unicykil content in just canversashon?
__________________
Steve
Hop Drop & Roll
“If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your
shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV.” – Homer
UniBrier is offline   Reply With Quote
Old 2011-12-08, 06:07 PM   #9
Peace Frog
Registered User
Thanks for the replies, i'm able to take it to a bicycle store tomorrow and i'll see what i can do. (I hope they could fix it, a new frame costs 150 euros)
And as for wrecking the chrome plating, i've never liked it and was considering painting it to black since the day i got it.
Old 2011-12-11, 02:31 AM   #10
feel the light
level 1 fat guy
I did a lot of work as a welder
Quote:
That frame is mild steel, and you could bend it such a small amount, and straighten it cold 20 times or more before it would crack. Heat is just an added complication in your case.
I would suggest buying a bottle jack, 10-15 $ at Sears or an auto parts store. Then all you need is a beam to strap the uni to, and you can use the jack to precisely bend the frame. Sask's idea would work, but requires more skill, with a jack, you can get it just right.
John's idea about welding gussets has some merit, but I would wait and see if you can't just learn to ride it without bending it again. In any event, it can be straightened many times from such a small bend without worry of making it weaker.
feel the light is offline   Reply With Quote
Old 2011-12-12, 12:05 PM   #11
Peace Frog
Registered User
Guys at the bike store straightened it and told me that the frame tube was so thin that it's like a dough. In order to prevent bendings, he also suggested adding gussets but chrome plating will burn in that process.
If only i knew buying a giraffe was going to cause so many problems...
Reply
Tags
bent, frame, giraffe
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bent KH Frame SkierAlex General Unicycling Discussions 25 2008-06-25 10:46 PM
Bent N36 frame lpounds General Unicycling Discussions 4 2008-03-29 02:41 PM
Help Bent Torker TX frame cmsustud19 General Unicycling Discussions 4 2006-06-13 02:32 AM
bent frame fix? ChangingLINKS.com General Unicycling Discussions 10 2005-08-22 03:59 AM
bent frame? jeff d tuttle General Unicycling Discussions 2 2000-12-03 07:23 PM
Copyright © 2001-2005 Gilby
Page generated in 0.08012 seconds with 10 queries
