Unicyclist Community
Reply
Old 2011-11-04, 07:55 PM   #1
wobbling bear
GranPa goes-a-wobblin'
wobbling bear's Avatar
Question a purely theoretical question about gear ratios for a unicycle
as the title says it is a purely theoretical question.
Imagine that you have a gearing system on your unicycle with a fantastic number of gears (like on a bicycle) - let's say 9 or 13 gear ratios ...
- what could be the minimum and maximum gear ratio a "normal" unicyclist can withstand?
- what could be the spacing between those gear ratios (uniform or not?)
I feel intuitively that the comparison with bicycle gear ratios do not stand....
__________________
One Wheel : bear necessity
wobbling bear is offline   Reply With Quote
Old 2011-11-04, 08:32 PM   #2
tholub
Totally Doable
tholub's Avatar
Physically, I don't think there's a significant difference between how bikes and unicycles use gearing. With bike-length cranks, we should be able to push the same kinds of gears that fixie riders do. There's no particular reason why you shouldn't be able to run a 80"-90" gear in a flat time trial, for example. Similarly, you should be able to gear down a significant amount. We can ride a 12" unicycle, why couldn't we ride a 12" gear?
The thing that's different is that it's scary to go that fast on a unicycle, and our geared unicycles have slop and sketchy shifting systems.
tholub is offline   Reply With Quote
Old 2011-11-04, 10:44 PM   #3
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
High gears on unicycles become increasingly hard to control, so it's not quite the same as on a bike where you're just providing power to drive the thing along. But probably with practice a good rider could make use of a pretty high gear. Personally I find it very hard to ride a Schlumpf 29er on 150s, which is only about half of a bike on a 90" gear even allowing for the shorter cranks. But people who ride gunis regularly are happy with Schlumpf 36ers on 125s, so perhaps it's not such a problem with practice.
What's the highest gear anybody's been known to ride on a unicycle I wonder? That thing Jogi built with external epicyclic gearing (steampunk work of art!) was about 2.5:1 on a 28/29" wheel wasn't it? So something like 72" - and somebody raced that at Unicon XIV so it was certainly doable.
Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski)
"I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule)
rob.northcott is offline   Reply With Quote
Old 2011-11-04, 11:20 PM   #4
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
starting with a Rholf as a base line (we are dreaming right?) 14 gears, 13.6% gear steps with 11 as fixed gear.
36" wheel with those gearing ratios would have a bottom end of 10 gear inches and top of 53. not even as high as a Schlumph and lots of people would like a higher gear.
Flip the input and output and make 4th gear the fixed gear and things get much better
36" wheel would then have a low of 24.5 and high of 129 gear inches. not sure if anyone would be able to handle 129 gear inches.
a 24" wheel would have a low of 16 and high of 86. Sounds good to me.
__________________
saskatchewanian is offline   Reply With Quote
Old 2011-11-04, 11:39 PM   #5
skilewis74
Stupidity gets you 2 of these:
skilewis74's Avatar
Send a message via Yahoo to skilewis74
Quote:
Also because of the wheels' inertia, stability increases on a b*ke, but for us instability increases at high speeds do to the slop in the hub and the wobbling from the cranks.
Eventually I bet all the slop will be taken out of the hub, so that wouldn't be contributing to instability, but I can't see how one would counteract the wobbling from the cranks/pedals aside from holding onto something like the handle or bars.
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist
What's next?
Learn2Ride&doTricks
TrialsClasses&Building
skilewis74 is offline   Reply With Quote
Old 2011-11-05, 12:45 AM   #6
tholub
Totally Doable
tholub's Avatar
Quote:
Bikes have cranks and pedals, too.
Old 2011-11-05, 01:18 AM   #7
johnfoss
North Shore ridin'
johnfoss's Avatar
Low gears would work great (to a point of ridiculousness, I think). High gears would be much more limited. Everyone remember their first few times riding a geared unicycle? A geared 36" in high gear? Hard to handle, and hard to master. Raise the ratio and it gets progressively harder to master, to the point where it might be no fun at all.
I once rode a short giraffe with a 3:1 ratio, on what I think was a 20" wheel. I could ride it, but the idea of using it to go real fast just seemed stupid at the time. Especially as it was a giraffe, with a small wheel below the crank axle. On a heavy 36" wheel it would be more stable, and probably easier, but I'm having a hard time trying to picture 3:1 on a 36", knowing what 1.55:1 feels like. I think it would reach a point where the stress level on the rider, both physically and mentally, would really suck. But we have yet to find out how high that would be...
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2011-11-05, 02:36 AM   #8
tholub
Totally Doable
tholub's Avatar
Quote:
I think a Schlumpf is significantly harder to master than a unicycle with more conventional gearing would be, because the frame acting as a lever arm changes the behavior of the unicycle.
If we solve the engineering problem of creating a gearing system with easy shifting and without changing the characteristics of the drive system itself, I think higher gears will be manageable.
Old 2011-11-05, 04:07 AM   #9
RossRacing
Custom Unicycle maker
RossRacing's Avatar
I have never rode a Schlumpf, but I am curious as to what behavior your are talking about. Isn't the frame always a lever? The frame holds the weight (me) above the pivot point (axle).
So is a Schlumpf in the 1:1 gear ratio much harder to ride than a conventional unicycle? I understand there will be a little bit of slop in the drive train, and a bit more weight. Anything else?
RossRacing is offline   Reply With Quote
Old 2011-11-05, 05:40 AM   #10
Yeti
www.unicycling.de
Yeti's Avatar
Location: Headquarters at Wiesloch, Germany, but travelling the world frequently
Quote:
Yes, it is a lever. But you don't notice when riding. And it's nothing that affects the stability of the frame. In early days of geared unicycles there was much discussion about that torque effect. People suspecting it would bend the frame, or make the unicycle unridable as the frame would be forced forth or back resulting in immediate dismounts. But nothing of that happened.
You feel the additional weight, especially when riding uphill or downhill.
Then there is some axle tolerance. That is something you notice, but it does not interfere with riding. It kind of feels like a loose crank. But you get used to it quite soon. The only thing you need to be careful about is when the crank actually comes loose. That is harder to notice compared to a non-geared hub.
__________________
Wolfgang
Quote:
Originally Posted by some mountain biker
War für mich sowas wie eine Yeti-Sichtung. Hätte nie gedacht, daß das geht ...
Yeti is offline   Reply With Quote
Old 2011-11-05, 05:49 AM   #11
tholub
Totally Doable
tholub's Avatar
A Schlumpf in 1:1 gear is more or less like a normal unicycle; somewhat heavier and with a bit of slop, but not anything you'd have a problem with.
A Schlumpf in high gear is significantly different than a normal unicycle. A 24" Schlumpf is much harder to ride than a 36" ungeared Coker, despite the gear ratio being similar. That's partly because when you're in high gear, the frame is constantly pushed forward by the lever action of the hub; learning to counteract that action is a skill that takes many hours of riding to perfect, and for me it still causes difficulty in situations like riding down steep hills under braking.
Old 2011-11-05, 05:56 AM   #12
Yeti
www.unicycling.de
Yeti's Avatar
Quote:
Really? I personally can't notice that effect on a geared 29" or smaller. On a geared 36" I think I can feel it when I pay attention. But it is nothing I need to care about when riding.
__________________
Wolfgang
Old 2011-11-05, 05:59 AM   #13
tholub
Totally Doable
tholub's Avatar
Quote:
I don't notice it when I'm riding normally, but I definitely notice it when I'm starting up from a start, when I'm riding technical off-road, or when I jump, among other things.
Old 2011-11-05, 08:02 AM   #14
saskatchewanian
ERIC P
Then you need the DACKOROMAN DRIVES SYSTEM
sorry, couldn't resist
__________________
Old 2011-11-05, 08:58 AM   #15
skilewis74
skilewis74's Avatar
Yes, but they don't contribute to instability because of the second wheel, lower pedal rpm, ability to coast, lower center of gravity, and other aspects of the frame's geometry.
__________________
What's next?
Learn2Ride&doTricks
Reply
Tags
gear, purely, question, ratios, theoretical, unicycle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
gear for a uni? idoelkana General Unicycling Discussions 6 2011-07-27 06:25 AM
How about a fixed gear hub instead of a Schlump? Nurse Ben General Unicycling Discussions 72 2011-07-11 11:56 PM
Gear ratios, cranks lengths and geared unicycles. UnicycleJuggler General Unicycling Discussions 9 2008-12-13 12:46 AM
theoretical science question--help requested BillyTheMountain Just Conversation & Introduce Yourself 15 2007-12-25 12:59 AM
Copyright © 2001-2005 Gilby
Page generated in 0.14083 seconds with 10 queries
