Unicyclist Community
Reply
Old 2011-09-05, 02:18 PM   #1
mountain shooter
Registered User
how to start riding a 36" and other 36" ???
I am a OK rider on a 26 and have the opportunity to buy a really nice 36" for a reasonable price. How hard is the transition? It comes with a disc brake but it sounds like they are not for slowing you down on mountain roads but just slight inclines. Is this true? How do I protect this really nice uni from getting trashed as I learn? What else do I need to know/forgetting to ask? Any advice is greatly appreciated.
Thanks
mountain shooter is offline   Reply With Quote
Old 2011-09-05, 03:32 PM   #2
piranhamatt
Registered User
i went from a 24 to a 36 and it was a completely different way of riding, getting on is allot harder, i found that a rolling mount is easiest for me.
as for the brake, i would not ride a 36er without one, i have 110mm cranks on it so i have little stoping power through the pedels, the brake means i can stop allot quicker than i could do evan with long cranks on.
if your worried about braking it, try to get an old battered seat and stick that on, also put some cheap pedels on, once your confident with getting on and riding it, put the good seat and pedels back on
also knee protection and gloves are very useful, while going 19.59mph i came of, my knee guards saved a hospital trip
piranhamatt is offline   Reply With Quote
Old 2011-09-05, 03:35 PM   #3
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
I Have seen people who have only ridden a 20" jump on and ride no problem but most people have to basically re-learn how to mount. Mounting a big wheel (36) is a bit different than smaller ones. Once you are on you shouldn't have much trouble with the riding itself.
I haven't used the impulse break but it should be good enough for some moderate downhill riding. If you feel like you need more breaking power you can get a bigger disk for the break.
The only thing you can damage on most 36ers from dropping repeatedly etc, would be your handle. The shadow handle uses replaceable bar ends. I would put handle bar grips on them but if they do get wrecked they are pretty cheep to replace.
Oh and keep the break handle protected by the handle bars so it doesn't hit the ground in the event of a crash.
__________________
saskatchewanian is offline   Reply With Quote
Old 2011-09-05, 06:29 PM   #4
juggleaddict
late-night rider
juggleaddict's Avatar
Send a message via AIM to juggleaddict
I was one of the fortunate ones. I was free-mounting on the first day. It's certainly different though. My suggestion is to jump higher than you think you need to. The important thing is to get your body on top of the wheel, and in the case of a big wheel that takes some commitment.
for the record folks. . .
brake: a device used for stopping or slowing motion (noun)
break: destroy (verb)
this bugs the living snot out of me. . . don't take it personally.
edit: I personally think the rolling/running mount is the easiest, and it's my regular mount for the 36er. It's by far the most versatile because you can mount at a pretty steep incline even with small cranks. it gets the wheel moving before you even hop on. You may want to learn a static mount first, but if you do, find a good downhill grade or a small ledge to make it easier. : ) Happy riding!
__________________
Steel is real! => I ride a Nimbus!
juggleaddict is offline   Reply With Quote
Old 2011-09-05, 08:28 PM   #5
DavidHood
Cokering rails2trails asphalt
DavidHood's Avatar
Quote:
Once you are up on it, not too different. The momentum (both speeding up and slowing down) is greater and turns are wider. I came from a 24" MUni and it did not take too long to pick up on it.
I also have an Impulse but I ride mostly asphalt and don't go down too many "mountain" roads. The brake is very nice to slow down especially with short cranks.
Mine is proof, the Impulse can take a beating. I never hesitate to drop mine when it is more important to get my body out of the way first. Don't worry about a little scratch here and there. Bar ends and seat bumpers are cheap to replace. Do, however, heed Saskatch's advice and protect your brake lever with the handlebar. Have fun!
__________________
36" KH/Schlumpf GUni, FOSS tube, 2.25" Todd tire, 137mm Spirit, Shadow, Slim
29" KH MUni, 2.4" Ardent, outboard disc, 165/137mm Spirit, T-bar, Freeride
26" Nimbus Oracle MUni, 2.5" HighRoller, inboard disc, 165 Venture, NurseBen handle, Freeride
DavidHood is offline   Reply With Quote
Old 2011-09-05, 11:41 PM   #6
MuniSano
Hartman Rocks, Uncompahgre beyond..
MuniSano's Avatar
Some other advise:
Start out with longer cranks, like 150s. Makes mounting a bit easier and you'll have a bit more control once you're up and riding. As you build more skill and confidence you can go to shorter cranks.
I've had pretty good luck with static mounting my 36er, even on my first day of riding. I learned from other advise on this forum to position the cranks a bit lower than you would for your smaller uni. For example: I typically mount my 24/26 with the cranks basically level and go into a static mount. With my 36er I have the cranks more like 10 o'clock and 4 o'clock. If you haven't learned to static mount on your normal uni, I'd strongly suggest learning it, it is, by far, the most useful unicycle mount there is.
Most importantly, have fun with it! There is nothing like zooming around on that massive wheel!
__________________
munisano
MuniSano is offline   Reply With Quote
Reply
Tags
36 and other 36, riding, start
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Stretching a 29" to fit a 36'er - How Big? One Wheel Good General Unicycling Discussions 5 2011-04-19 03:57 PM
Moving, how to ship 36"? JusticeZero General Unicycling Discussions 9 2011-04-06 05:08 PM
How to buy a 36" coker-like-uni for less than $350 danechka Unicycling Articles and Tutorials 1 2011-04-01 01:06 PM
[For Sale: New Zealand] Coker 36" and Nimbus 20" Trials Miles Trading Post 5 2011-02-15 06:34 PM
Growing up to a 36" KiwiRichard Just Conversation & Introduce Yourself 13 2010-12-30 09:57 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07489 seconds with 11 queries
