#16 | |
Stupidity gets you 2 of these:
Quote:
Looks like: Flattop Extreme - LX LX pro - Nimbus II Flattop OR - DX - Nimbus Muni Since you already have riders in the house, there are some unis too right? Why not learn on those before getting your own quality uni appropriate to the riding you want to do. If you need to get a new uni to learn, I'd get a cheap uni, like the Club and maybe some longer and shorter cranks (especially on a 24") which are cheap on a cotterless hub. The longer cranks will make learning some of the skills easier and the shorter ones will be better for distance. Taller people tend to preffer bigger wheels. The tipping point seems to be 6'. For me learning on a 24 was terrifying. A 20" w/ 125 cranks was a bit easier and 150 cranks helped quite a bit w/ getting over the fear and learning all the basics. I'm 5'10".
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist What's next? Learn2Ride&doTricks TrialsClasses&Building Last edited by skilewis74; 2011-09-05 at 04:48 PM. |
#17 |
Registered User
All great advice.......
....thank you all.....
Just a quick update. I went out today for the first time and rode my son's 20" Sun -- it's pretty old. Made it 15 feet after 30 minutes practice before a horrific spill But I'm alright. My boys were riding all around me with big grins on their faces. I think they like being able to do something that I can't.I did notice, however, that ........ how can I say this............ .....unless you have a forgiving seat........it's very easy to do some damage to that "especially sensitive area" -- or your NUTZ. Any idea here? I understand some of the stock seats are fairly good...... I'll be out there again tomorrow. |
#18 |
n00bie
I found that the Kris Holms street seat along with the adjustable seat post to be a really good purchase. It sounds counter intuitive but if you raise the front more it will put you more on you sits bones and less on the sensitive areas.
#19 |
XC Muni
Get a uni that will compliment the unis your boys are riding now, ie something they can grow into, share, etc...
I previously had all sizes and some duplicate sizes for my and I to ride, but he has since moved onto teen stuff and rarely rides, whereas my riding has grown. I have recently started thinning the uni quiver so that I have a uni for every condition. When my son rides with me he can choose one that I'm not ridng ![]() If you and your two sons are going to continue to ride, you should probably go ahead and buy high quality unis, so double wall rims, splined cranks, chromoly or aluminum frames, etc... You can always sell a good used uni, whereas cheapmused unis are left at the dump or become $5 garage sale items. Three riders, you need three unis, I'd start with one each: Trials uni (19"/20") Muni 24 or Street 24 One last piece of advice: i have found that when embracing a new sport, anything you can do to make it easier, more comfortable, and more enjoyable, are well worth the expense, ie get a good seat. Last edited by Nurse Ben; 2011-09-06 at 01:00 AM. |
#20 |
Registered User
seats
Nurse Ben & DhEXED,
Thanks for the advice.........it seems many are impressed with the Kris Holms' seat....... sounds like that is the way to go.... Will it fit any uni I get..... I'm assuming "yes"...... Very EXPENSIVE!
#21 |
ERIC P
The only one it will not fit (without changing the seatpost) is the Torker LX.
Yah good saddles are expensive, often more than a cheep unicycle but it is a investment that your back side will thank you for. As for your man bits, try to sort of scoop them out of the way with the front of the saddle before you sit down.
__________________
My friends, love is better than anger. Hope is better than fear. Optimism is better than despair. So let us be loving, hopeful and optimistic. And we’ll change the world. - Jack Layton |
#22 |
Skateboarder to Marine to Unicycler
Once again, I seem to be the minority here, but I find the KH style saddles more uncomfortable than the el cheapo that came with my $69 Avenir. As for resale value on a nice UNI, unless you live somewhere that UNI is very popular, you are going to lose a lot of money on the resale. So, you can't really use that as an excuse to spend $300 on a nice UNI versus $100 on a cheap UNI. I highly suggest that you learn how to ride before you decide to shell out $300 on a UNI that might not fit your riding style or preferences. I would also test the KH seat before paying the money for that either.
#23 |
Registered User
compromise
I appreciate all the perspectives on this.....
I thought of a compromise....for example, I noticed the Nimbus II has some sort of gel seat.......I'd assume this is somewhere in between the KH and a cheapo seat. Secondly, can someone explain all the attention given to whether or not a uni has an ISIS hub. What exactly does this do....and would it be necessary in my situation? |
#24 | |
I'd rather be unicycling.
Quote:
__________________
My Website: www.Unitips.ca for trick tips and gear advice! Visit Municycle.ca Canada's online unicycle source! Check out the Municycle.ca Blog for news, tutorials and more! |
#25 |
Registered User
I'll toss in my opinion. I'm 49 (5'9" and 185lbs), and I just learned this February after getting my 13 year old son a uni for X-mas. I actually learned on his club 20 (he learned in a flash so we quickly upgraded him to a Nimbus MUNI), but I could only go a little ways down the street. I then bought a Nimbus II, which was a huge help! I found it much easier to ride than the 20, and putting on 145mm cranks (stock was 125) helped even more.
A couple of other things that I've learned: 1. I ride almost every day, but until very recently, I found my son's Nimbus Muni 24 much harder to ride because of the weight and inertia of the wheel. I finally seemed to have developed my skills enough that I can handle the weight. The Nimbus Muni is very nice, but I think the much lighter Nimbus II is a lot easier to ride for the novice. 2. If you buy a Nimbus II, at purchase upgrade the seat to a KH, and the pedals to something a little bigger, and I think the longer cranks help if you live in a hilly area like me (Atlanta). Doing this at purchase will save a good bit of money. 3. The tire makes a huge difference. For example, the stock tire on the Nimbus II is very nice on the street, but not in the dirt. The first dirt type tire I bought was virtually unrideable! It just did not work on a unicycle. With the help of folks on this forum, I settled on a Kenda K-rad, which works pretty well on both the street and for my mild Muni riding. 4. I would rule out the 20. As an adult you probably will want to ride around the neighborhood, etc. The 20 is great for tricks (my son juggles while riding his 20), but it's just to slow to go anywhere. Last edited by rpt50; 2011-09-07 at 12:49 AM. |
#26 |
XC Muni
The Nimbus seat has a lot more curve than a KH, so not great if you are worried about jewel issues, also the cover is stapled onto the base so it can't be easilly replaced nor can the foam be trimmed.
$320 for a Nimubus muni. Think of it as an investment, worse case scenario is that you and your boys don't ride it, then in a couple years you sell it for $225-250, total cost $100 or less. In the meantime you have a wonderful uni that'll help you learn to ride in comfort. I did what I am suggesting to you, bought a Nimbus muni 26er, one week after my son and I started on a Sun 20", now three years later I have: KH 36 KH29 KH 26 Guni Nimbus Oregon and of course, a Sun 20 ![]() It's just money. |
#27 |
Registered User
Nimbus
Nurse Ben,
I like the "it's just money" line......... that just might push me over the edge. I always like to say of my children and deciding to go the extra mile with them, "They're only little once"......so I better get ordering. Speaking of ordering....... is unicycle.com the best place. I know there are some others --- allunicycles.com, for example......I think their price is a bit cheaper on the Nimbus Muni......... any leads in this area? |
#28 | |
Fallen Rider
Quote:
Now that I've decided to push myself in more directions I have a KH20 with an ISIS hub. I'd also choose ISIS for anything geared and/or Muni. As soon as my wallet recovers from the last onslaught of unicycle (related) purchases.
__________________
[ Karlsruhe/Germany - kamikaze@bsdforen.de ]
---- Grizoo: Wowwww! you guys should get a uni or something !!!!! ![]() |
#29 |
Peddle Pushing Papa
I'm another newbie to the sport who is also over 40 (49 next month). I'm 6'0", 180lbs. and went with the Torker LX Pro and love it. I feel that $172.00 was well spent. It's a very solid machine and I don't feel like need to upgrade anything (although I did get an aluminum Kris Holm seatpost just to add a bit of bling to it). I plan to buy and second uni (after I'm comfortable with my skills) for off-roading. That will be a 24 or 26'er, but for now the 20 is great to learn on.
__________________
"Imagination is everything. It is the preview of life's coming attractions." -- Albert Einstein |
| Tags |
| advice, newbie |
Similar Threads
| newbie advice | riptheuni | General Unicycling Discussions | 7 | 2009-01-14 10:27 PM |
| Newbie would like some advice | Vince | General Unicycling Discussions | 4 | 2006-07-19 11:19 PM |
| Newbie advice | dbp_1999 | General Unicycling Discussions | 5 | 2004-08-12 03:09 PM |
| Newbie looking for advice | nu_uni | Just Conversation & Introduce Yourself | 1 | 2003-01-01 10:11 PM |
| Newbie - takes advice and soars | jason | General Unicycling Discussions | 12 | 2002-06-18 04:58 AM |
