Unicyclist Community
Reply
Old 2011-07-30, 03:09 AM   #1
LoneReaction
Registered User
LoneReaction's Avatar
Smile Totally new to this, need help IDing new uni
I'm attempting to learn how to unicycle, and got myself a used uni. Paid (converted to USD) around 100 bucks for it. 24"!
I read loads of threads here and some people have suggested that 20" is more suitable for learning, but I want to be able to go about the neighborhood or atttempt Muni in the future. I am only 5'3". I've had only 2 hours attempting to ride. I took half an hour before I could move a meter while holding to a rail. Now I can go up and down a railing with some difficulty.
I mountain bike as well, glad to have shin/knee guards and a helmet. It's hard as hell, but I'm going to keep trying!
It looks like a Qu-ax, but I have no idea.
Also, there is a strange sound coming from the uni when it bounces. I have asked the owner about it and he is not sure where it's coming from.
Quote:
Originally Posted by TopHatPlus View Post
Hello, The sound to me is something loose, and in the area of the bearings, i would probably take the wheel off and try just bounce the wheel (the bearings are attached to it) and that should help you identify whether its the wheel or on the uni.
Brand - i have been riding for 3 days, and reading about for a week so i have VERY limited knowledge but it has a alexrim DX32 which is what mine runs (but a 20") and it look an awful lot like a Norco, so thats my guess
http://www.thecyclepath.ca/images/20...o/unicycle.jpg
i google images norco unicycles and this was the first image, it looks like the 24" version of the idle one.
LoneReaction is offline   Reply With Quote
Old 2011-07-30, 03:48 AM   #2
tholub
Totally Doable
tholub's Avatar
The unicycle is a cheap knockoff. The rim is decent, the seat sucks. With a square taper hub it's not really suitable for MUni.
The noise is probably one of the bearing holders being loose. Tighten them to be a little bit more than hand-tight, but not so tight that the wheel won't spin freely.
Good luck!
tholub is online now   Reply With Quote
Old 2011-07-30, 04:53 AM   #3
johnfoss
North Shore ridin'
johnfoss's Avatar
He's a beginner. For learning, the seat and the rest of the unicycle are fine. Your seat is not the most comfortable, but it will take nearly unlimited drops (unlike the stuff that was available when some of us were learning). Stick with the 24", the difference between 20" and 24" for learning was slight. I know I would have done better on a 24" (I learned on a 16" tricycle wheel with solid plastic tire).
When your axle breaks, then it's time to get a beefier MUni.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2011-07-31, 08:57 AM   #4
LoneReaction
Registered User
Thanks for the advice guys. I found the source of the noise. No idea what to do about it though, so just fixed it back together.
Old 2011-07-31, 01:28 PM   #5
TopHatPlus
Registered User
Hey, it's just a spacer between the hub and the bearing, i am not sure how difficult they are to move, but you could slide you bearing so that its touching, which would have been how it was from new. But if the noise doesn't bother you then i wouldn't worry about. Hows the learning going?
TopHatPlus is offline   Reply With Quote
Old 2011-07-31, 03:39 PM   #6
LoneReaction
Registered User
Today I went mountain biking, but when I got home I rested a bit and went outside to try unicycling again for about 1.5hours.
I wear "sock" type knee/shin guards, which only covers half of my shin.. unfortunately I hit my shin on the pedals where it was not covered. At the end I scratched my calf on the pedal pins as well. Nothing serious, didn't hurt much. I will be buying plastic pedals tomorrow, and wearing longer socks.
And on to the good part, I managed to get in a few rotations of the wheel. My best was about 4-5 revolutions at the end of which I crashed into a bush, lol! At first I had one hand on the rail and the other holding the front of the seat, but I realized that not holding the seat seemed to be better.
Also, I found out that you have to control your hips forward/backward position. I kept falling backwards, so I tried "thrusting" my hips out more. It worked, but the feeling is kind of scary.
Glad I got a used uni to learn on, I fell off so many times!
Old 2011-07-31, 04:34 PM   #7
tholub
Totally Doable
tholub's Avatar
It's a rule; you'll always hit yourself at the spot you're not protected.
At first, you're probably better off not holding the seat; having both arms out for balance will help until you're more solid.
Try to keep good posture (back straight), and keep as much of your weight on the seat as you can.
Old 2011-08-01, 02:10 PM   #8
LoneReaction
Registered User
Learning Diary.
Quote:
I read this over and over again in the forums, and it's true. I think I will make this thread my "learning diary".
Today I bought plastic pedals and long socks to cover up the exposed areas of my shin/calf.
Day 3 (3.5h-5.5h)
I practiced for about 2 hours. For a bit more than an hour, I did not make any progress, making only 2-5 pedal strokes. Once I got 10.
I tried to sit straighter, and use my hips for speed control (hips front = go forward, hips back = go backward). This seemed to work really well as a mind trick!
I made 20 strokes, then 30. After that I had a few more 10s, and one or two 20s.
My sister was jogging around the neighborhood and I asked her to take a video of me using her phone. (Will upload later when I get the video!)
Old 2011-08-01, 02:37 PM   #9
jbtilley
Muni Foot
jbtilley's Avatar
Congratulations. If you are already making 20-30 consecutive strokes you're not far off at all.
One thing I remember doing in the beginning was going to a school with a track. I used the track to measure progress/distance and it was nice because it was completely level and had some gradual turns to practice turning.
jbtilley is offline   Reply With Quote
Old 2011-08-01, 04:41 PM   #10
LoneReaction
Registered User
I actually practiced on the opposite side of the drain, but it was late and this side had lights. The 2nd run was really wobbly and funny, lol.
Old 2011-08-01, 09:11 PM   #11
aarons
Eating a sandwich
aarons's Avatar
You're practically there. One or two more days and you'll have it. After that it's free mounting, and then you can go anywhere.
aarons is offline   Reply With Quote
Old 2011-08-03, 03:45 PM   #12
LoneReaction
Registered User
Day 4 (5.5-7h)
For the first 15minutes, I could only do a few strokes. At around 20mins it started to come to me, and I could do >10 strokes. Highest I've gotten was 72strokes. I'm starting to be more consistent now, really happy I stuck with it!
Hurt my ankle on a awkward fall though.. probably will be okay by tomorrow.
Reply
Tags
beginner, used uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need some help convincing my girl to accept unicycling riverman General Unicycling Discussions 114 2012-06-25 01:06 AM
Need Help with my first Uni markonewheel General Unicycling Discussions 37 2012-06-21 09:06 AM
Totally new to this, need a little help! LoneReaction Just Conversation & Introduce Yourself 4 2011-07-30 03:04 AM
New Uni Help... BlueFlyer83 General Unicycling Discussions 10 2011-06-02 01:05 PM
Do you think I need a new 20"? Dane M General Unicycling Discussions 12 2011-01-26 08:03 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11059 seconds with 11 queries
