Unicyclist Community
Reply
Old 2011-07-10, 02:46 PM   #1
unirox13
Unicycling Ninja!
Send a message via AIM to unirox13
Will Moments fit onto an old style KH hub?
sorry for the new thread folks, I searched a little but was unable to find. I'm looking at buying a Muni online, however the one I'm looking at has the old style KH cranks/hub. Is it possible to swap those cranks out for Moments without replacing the hub? If not are there any other cranks that are compatible with the old style hub and still readily available?
__________________
The World is on fire, are you the smoke, or the flames?
unirox13 is offline   Reply With Quote
Old 2011-07-10, 03:26 PM   #2
stingingkneeben
Ben Glynn
stingingkneeben's Avatar
if its isis there compatible
__________________
when life gives you lemons say " hey thanks free lemons "
stingingkneeben is offline   Reply With Quote
Old 2011-07-10, 04:03 PM   #3
tholub
Totally Doable
tholub's Avatar
If you mean the KH/Onza hub, no. None of the currently manufactured uni cranks will fit.
tholub is offline   Reply With Quote
Old 2011-07-10, 10:21 PM   #4
RyanB
Inactive unicyclist
RyanB's Avatar
KH/onza cranks are still strong so there should be no worries there. If you want to change length, UDC may well have shorter cranks in stock.
__________________
360unispins
RyanB is offline   Reply With Quote
Old 2011-07-10, 11:04 PM   #5
simonb
Team Voodoo Unicycles
simonb's Avatar
Quote:
Saying that, in some cases the cost of replacing those old cranks is more than upgrading to an ISIS hub and cranks!
__________________
simonb is offline   Reply With Quote
Reply
Tags
fit, hub, moments, style
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
will th KH 20" rim fit this maxxis cc tire? UniB General Unicycling Discussions 2 2011-06-18 05:12 AM
Qu-Ax Debut Frame on KH hub/Nimbus Hub emile General Unicycling Discussions 4 2011-05-09 11:39 PM
what tires will fit? knoxuni General Unicycling Discussions 7 2011-04-14 09:11 PM
Will this tire fit this rim? MuniAddict General Unicycling Discussions 17 2011-02-02 09:31 PM
Will this fit a K1 base? TonyTorchia General Unicycling Discussions 5 2010-12-19 05:06 AM
Copyright © 2001-2005 Gilby
Page generated in 0.06572 seconds with 10 queries
