Unicyclist Community
Reply
Old 2011-05-20, 02:47 PM   #1
madams
Registered User
brakes or no brakes on your 29 or 36 in
Do most people who ride these two unicycles have brakes or not?
Mike Adams
madams is offline   Reply With Quote
Old 2011-05-20, 03:17 PM   #2
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Depends on the type of riding. I don't need a brake on my 36er for road riding, since 99% of it is done on the beach bike paths, which are mostly flat. But the times when I use it off road, including my 29er, then yes, I always use a brake.
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2011-05-20, 05:24 PM   #3
davidp
Registered User
davidp's Avatar
On my 36" I run a drag brake (V-brake attached to a friction shifter). When I had a 29" I ran a V-brake with a standard brake lever. I don't use my brakes on every ride but it's nice to have them and adapting a V-brake is cheap.
davidp is offline   Reply With Quote
Old 2011-05-20, 06:13 PM   #4
MuniSano
Hartman Rocks, Uncompahgre beyond..
MuniSano's Avatar
The age old answer to this question (if you'd done a search) is this: If you have to ask you probably don't need them.
__________________
munisano
MuniSano is offline   Reply With Quote
Old 2011-05-20, 09:36 PM   #5
Hung Like Saddam
Proper Job!
Hung Like Saddam's Avatar
Send a message via MSN to Hung Like Saddam
Quote:
This
I only put brakes on my 29" last week, had them on the MUni since last year, Had the 29" 2 years and ive only put brakes on now as im getting more and more addicted to 29"ering over everything and anywhere.
If you're asking us, you probably don't need them.
__________________
The mountains’ my playground, a place to unwind
Where negative thoughts are left far behind - Terry Peterson
"I'll be racing the clouds home"
Hung Like Saddam is offline   Reply With Quote
Old 2011-05-20, 10:19 PM   #6
kb1jki
Unicycles on my mind...
kb1jki's Avatar
I run 150 mm cranks on the 29er, and 125 on the 36er... short cranks and big hills around here means brakes on both. I prefer disc brakes to any rim brake option.
__________________
Retrofit Disc Brakes to your existing unicycle today!
kb1jki is offline   Reply With Quote
Old 2011-05-20, 11:25 PM   #7
deadbeatpope
Some call me Kevin
deadbeatpope's Avatar
I bought one a year ago for my 29er but still haven't installed it. Don't know if I will.
__________________
Art is a misspelled rat.
"The unicyclist is the purest form of rebel"
deadbeatpope is offline   Reply With Quote
Old 2011-05-20, 11:58 PM   #8
neilth
Registered User
I didn't run brakes and did absolutely dandy without them for a year... until I got into an uncontrollable descent and tore my acl
Always brakes for me from now on...
neilth is offline   Reply With Quote
Old 2011-05-21, 12:06 AM   #9
krjames
Registered User
That I think is what the OP was wanting to know. When should a rider start thinking about putting on brakes. So the question should probably be phrased "What sort of riding would you be graduating to that should cause you to put on brakes as a precautionary measure?"
As they say, good decisions come from experience, experience comes from bad decisions......
Have a nice weekend
I'm off for a 100km run, not much training so it should be interesting
James
__________________
"If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV."
— Homer Simpson
Haven't got the karate suit
krjames is offline   Reply With Quote
Old 2011-05-21, 01:59 PM   #10
harper
768 - It's in your DNA
harper's Avatar
The question asked was:
Quote:
The answer is obviously no. In the group of all 29" and 36" unicycles, those without brakes greatly outnumber those with brakes. First, read the question. Then just look around you.
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Old 2011-05-21, 04:14 PM   #11
Alan Hogan
The Highland unicyclist
Alan Hogan's Avatar
Brakes
I have brakes on everything!!
I actually use them to hold the wheel still when I am mounting
__________________
Unicycling in the Scottish Highlands
http://www.facebook.com/?ref=home#!/Highland.Unicyclist
Alan Hogan is offline   Reply With Quote
Old 2011-05-21, 06:30 PM   #12
vookash
vookash's Avatar
Send a message via Skype™ to vookash
I just removed the brake from my 29er because I put shorter cranks for road riding and they are not compatible with my brake. On the road I don't need the brake. Offroad I don't need it, but it feels so much better to have it and my legs are much much happier next day about it
vookash is offline   Reply With Quote
Old 2011-06-14, 05:01 AM   #13
ImFalling
Graham
I have been running my kh29 without a brake. But every time I go down a hill (even 10 metres), I lack confidence and get sore legs quickly. If the slope is steep, I find myself standing out of the saddle in order apply backpedaling pressure, which often enough causes a UPD. Uphill is easy, downhill is scary! I know that after a while, the backpedal muscles will strengthen and this will be less of a problem (never rode a fixed gear before uni).
Should I get brakes now, or persevere and try to become more comfortable without them?
Maybe put a fixed gear on my two wheeled contraption (single speed with flip/flop hub) to assist with backpedal strengthening?
ImFalling is offline   Reply With Quote
Old 2011-06-14, 01:39 PM   #14
davidp
Registered User
davidp's Avatar
Quote:
Both. If you can find or make some mounting adapters, there's no reason not to get a cheap cable brake now. In time you'll find you use it less on hills that once required it but there will still be times when it will come in handy.
Old 2011-06-14, 04:11 PM   #15
mbalmer
Is it June yet?
mbalmer's Avatar
I don't use brakes as much as I used to but I still like them for steep downhills. To me it's cheap insurance for a safer descent (when I need them). Sounds like you would benefit from adding a brake. It makes downhill more fun and much less scary. This is strictly an opinion thing though.
mbalmer is offline   Reply With Quote
Reply
Tags
brakes
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
29" or 36" for road cruising bluesman General Unicycling Discussions 39 2011-05-17 03:19 AM
Powdercoating Uni Frame in Portland, OR Tirving Unicycle Product Reviews 0 2011-03-19 06:42 PM
Minimizing your destructive effect in urban or outdoor environments? Dane M General Unicycling Discussions 36 2011-03-12 03:29 AM
Choose Your Weapon or Collect Them All? deadbeatpope General Unicycling Discussions 75 2011-02-13 05:16 PM
Do you need Brakes on your 36er? POLL bluesman General Unicycling Discussions 33 2011-01-05 02:44 PM
Copyright © 2001-2005 Gilby
Page generated in 0.09792 seconds with 10 queries
