Unicyclist Community
Reply
Old 2011-04-26, 05:29 PM   #1
Dane M
Muni Crash Test Dummy
Dane M's Avatar
Setting your tire circumference for cycle computer. Compression measurement?
Just wondering how you guys set the circumference for your cycle computers. Do you pump up to your favorite PSI, and then have someone measure it while you're sitting on it to factor for compression of the tire? Or do you just measure it normally and ignore the excess?
__________________
It's not as steep as it looks, just go!
www.DaneMehlPhotography.com
www.YouTube.com/DaneUni
Dane M is offline   Reply With Quote
Old 2011-04-26, 05:32 PM   #2
tholub
Totally Doable
tholub's Avatar
Quote:
Ideally you should do a roll-out test; put chalk or water on your tire, ride it, and measure the distance between spots.
tholub is offline   Reply With Quote
Old 2011-04-26, 05:38 PM   #3
SinisterJay
Registered User
SinisterJay's Avatar
Quote:
I'd imagine that inconsistency in your spin or any veering left or right could offset or compound any minimal change in tire shape based on rider weight.
__________________
Nimbus 24 MUni
Nimbus Trials
Triton 29'er w/MountainUni disc brake system.
SinisterJay is offline   Reply With Quote
Old 2011-04-26, 05:47 PM   #4
tholub
Totally Doable
tholub's Avatar
Quote:
If what you're trying to do with your computer is measure your speed and distance over the ground, you want to include wobble in your circumference calculation.
Old 2011-04-26, 06:03 PM   #5
SinisterJay
Registered User
true enough. I wonder if counting full crank revolutions over a few hundred feet, then dividing the distance by number of revolutions would give you a more accurate average. That is, unless you're super smooth ; unlike myself...
__________________
Nimbus 24 MUni
Nimbus Trials
Old 2011-04-26, 07:42 PM   #6
MuniAddict
Not "2" Tired
MuniAddict's Avatar
To determine the most accurate calibration number for your application (tire choice, body weight, etc.), or if your tire size is not listed in the chart you have, perform a ‘tire roll out’.
To do a tire roll out:
1. Mark a spot on the floor, and line up the tube’s valve stem with it.
2. Running the usual tire pressure and with the rider’s weight on the uni, roll the tire out one full revolution. When the valve stem comes back around to the ground, make a second mark on the floor. Measure the distance on the floor from point to point.
NOTE: This is often best performed parallel to a wall, to ensure the roll out procedure is done in a straight line. Or you can include some "wobble" to make it a bit more "real world" accurate.
3. Record this number in cm if your computer requires a 3-digit calibration # (or multiply inches by 2.54 for cm). Record this number in mm if your computer requires a 4-digit calibration # (or multiply inches by 25.4 for mm).
4. Enter this number in your computer for your wheel circumference.
To confirm my calculation on my strada wireless, I zeroed out my trip meter and rode one mile, according to markers on the beach bike path. It was almost exact, and the difference was quite negligible.
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2011-04-26, 08:04 PM   #7
MuniOrBust
show me the muni!
MuniOrBust's Avatar
Quoting from another thread:
Quote:
Originally Posted by MuniOrBust View Post
On my 24"x3" muni, I found a 2" reduction when I moved my uni one rotation with me on it, versus without my weight. So I confirm the above.
Then I tried a high psi (35) and a low (20), both with me on it, and I again saw about a 2" difference, from about 78" to 76".
That's a 2.56% reduction.
So, if I calibrated with a different PSI, my computer might say I went 10 miles, when I actually went about 0.25 miles less.
In 100 miles, I would have gone about 2.5 miles less.
Not a big deal to me, but I did the math so I thought I'd share it.
MuniOrBust is offline   Reply With Quote
Old 2011-04-26, 08:20 PM   #8
Klaas Bil
Sir Prince of Newsgroupia
In 2004 I did some statistical work on the actual roll-out value of Coker tyres, which at that moment in time was the only brand offering a 36" tyre. I also made some comments on what rollout actually means, it could be straight rollout (loaded or unloaded), or dynamic road rollout.
My report is on http://www.xs4all.nl/~klaasbil/coker_rollout.htm.
(It includes a download link for a spreadsheet that will estimate your Coker tyre rollout based on rider weight, tread wear and tyre pressure. That spreadsheet has lost some of its applicability since many riders now have other tyres than the original Coker. Those other tyres have probably slightly different dimensions.)
Klaas Bil is offline   Reply With Quote
Old 2011-04-26, 09:37 PM   #9
Dane M
Dane M's Avatar
Why would you factor in wobble? That's still distance that you are traveling, just not straight-line distance.
__________________
Old 2011-04-26, 09:58 PM   #10
tholub
Totally Doable
tholub's Avatar
Because most people are interested in measuring straight-line distance. We measure the marathon course to be 42km in straight-line distance; if you actually ride 43km due to wobble, that doesn't mean you get to stop 1km before the end.
Old 2011-04-26, 10:00 PM   #11
Klaas Bil
Say you want to train the exact distance of a marathon for an upcoming race. If you have done 42.195 km according to your cycle computer, you haven't reached your goal yet. Any race is about going from A to B being some specific distance apart, not about a traveled distance the way you define it.
Note that wobble typically "consumes" a few percent.
Edit: essentially saying the same as Tom.
Old 2011-04-27, 12:25 AM   #12
Dane M
Dane M's Avatar
Ah ok. So probably the best way to check after calibrating would be to measure out a perfect mile on flat ground, and ride it and adjust until it hits the mark?
__________________
Old 2011-04-27, 12:31 AM   #13
tholub
Totally Doable
tholub's Avatar
Now you're getting into the vagaries of measurement; how do you measure out a perfect mile on flat ground? Don't use your car, it's almost certainly wrong. Perhaps you're best off going around a track four times, but how do you know the track distance is accurate? Or whether a quarter mile is at the inside of the lane or center of the lane?
Old 2011-04-27, 12:38 AM   #14
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Ride the bike tour of a 26.2 mile marathon. The event organizers are pretty good about getting the distance right. The last one I rode in came out pretty much on the button with my computer. None of this is an exact science anyway, so I wouldn't stress too much about it.
__________________
UniGeezer.com
My videos
Old 2011-04-27, 12:41 AM   #15
Dane M
Dane M's Avatar
Quote:
Originally Posted by MuniAddict View Post
Ride the bike tour of a 26.2 mile marathon. The event organizers are pretty good about getting the distance right. The last one I rode in came out pretty much on the button with my computer. None of this is an exact science anyway, so I wouldn't stress too much about getting it perfect, which you never will.
I don't expect it to be perfect, but within range of reasonable error.
__________________
Reply
Tags
circumference, compression, computer, cycle, measurement, setting, tire
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
36'' - setting up the cycle computer jogglingflurpy General Unicycling Discussions 4 2009-06-14 06:19 PM
What circumference did you enter into your Coker cycle computer? Ken Fuchs General Unicycling Discussions 34 2007-08-13 11:01 PM
tire compression questions. gordito8me General Unicycling Discussions 9 2006-11-12 01:08 AM
Bike computer setting... ajp529 General Unicycling Discussions 3 2004-01-01 07:08 AM
setting up a computer on MUni joe General Unicycling Discussions 1 2003-11-29 10:26 AM
Copyright © 2001-2005 Gilby
Page generated in 0.09363 seconds with 10 queries
