Unicyclist Community
Reply
Old 2011-03-05, 06:39 PM   #1
Masoncade
Mr. Nicejob
Masoncade's Avatar
Question What is the most versatile uni?
hey, guys! I'm new here, and about to purchase my first uni. i have a question. i want to have the most versatile unicycle possible. i will mostly be doing street riding, and really want to get into trials and such. but there is one problem.
my parents are barely letting me get a uni as it is. i was planning on getting the club 24 in. from unicycle.com, but seeing as it won't hold up to the kind of riding i want to do in the future. the easy solution is to buy a trials once i get good enough. but as i said before, my parents are barely letting me get one in the first place, let alone another. i did a search and found out that i have just enough for a nimbus trials uni. what do you suggest i do?
tl;dr i want a very versatile uni for my first, will a trials do it. can only have one uni.
Masoncade is offline   Reply With Quote
Old 2011-03-05, 06:48 PM   #2
uninewb
Registered User
I Just bought a nimbues trials unicycle, it will come in the mail on thursday! I would say get the trials if you want to get to that eventually, and even if you dont you will never have any problems riding around town on it, I rode on a 20 inch for four years, but couldnt do any trials because it was a no name uni and would fall apart if I did. Imho the Nimbus is the best bang for your buck
uninewb is offline   Reply With Quote
Old 2011-03-05, 07:19 PM   #3
johnfoss
North Shore ridin'
johnfoss's Avatar
Trials and Street unicycles are very similar, so that Nimbus should be a great choice for your situation. The worse choice would be to buy a non-splined uni, like the Club, and ride it until it breaks, "proving" you needed something more in the first place.
A Trials won't be quite as easy to learn to ride on, but don't let that discourage you. EVERY unicycle seems impossible until you start to get the hang of it. Put plenty of air in the tire if you're still learning to ride, to reduce the friction. Once you start hopping around, you'll want to lower the pressure to something that gives more bounce, but always keep your rim off the ground!
In the end, no unicycle is "the most versatile" because it entirely depends on what you want to do with it. With activities ranging from indoor hockey to long-distance road riding, it's important to base your choice on the activity you will do the most.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2011-03-05, 07:36 PM   #4
Masoncade
Mr. Nicejob
Masoncade's Avatar
thanks guys!
anything extra i should get? (other than safety equipment) such as lube/grease/other things?
also, my inseam is 31 inches, should i go for the 300 or 400mm?
Old 2011-03-05, 07:47 PM   #5
Dane M
Muni Crash Test Dummy
Dane M's Avatar
The K1 clearance is still going on at makais.com
These are supposedly the stronger frames.
k1 Green Spirit
k1 Black Domina [Cheapest, but I think they're all the same besides different designs...]
k1 Alien Backflip
I bought the black domina, and it is SWEET. THe pedals are super super grippy though, so if you want to do street and pedal grabs and stuff, buy a $10 dollar pair of plastic pc pedals like these. The pedals they come with are like $100 dollar pedals, and I put them on my 24 muni and they're amazing.
Then there are also the devil frame K1's which are cheaper, but supposedly have a bit weaker frame as well according to other riders.
They look like this, and you can see a bunch of them when you search keyword: unicycle
Also a tip: Whenever ordering online from places like this, upon checkout there is often a spot for coupon codes. Go to google and search makais.com coupon codes and you might find some sweet coupons to help you lower the price or knock shipping off.
__________________
It's not as steep as it looks, just go!
www.DaneMehlPhotography.com
www.YouTube.com/DaneUni
Dane M is offline   Reply With Quote
Old 2011-03-05, 07:50 PM   #6
Dane M
Dane M's Avatar
Quote:
Originally Posted by Masoncade View Post
thanks guys!
If you're going for street and trials, your seat will probably be lower, so 300 should be fine. But if you're worried, and it isn't any extra cost, just get 400 and cut it down as you need to.
A good pair of shinguards and gloves can go a long ways in building your confidence as you learn to ride. Also helmets are always a good idea. I use Kris Holm Pulse gloves and 661 4x4 shin guards.
__________________
Old 2011-03-05, 07:53 PM   #7
Masoncade
Mr. Nicejob
Masoncade's Avatar
i'll look into them. do you know the specs for the uni?
Old 2011-03-05, 07:59 PM   #8
Dane M
Dane M's Avatar
The specs I know for my black domina.
Black domina frame 20"
k1 135mm street cranks
butterfly pedals
try-all tire
try-all seatpost
k1 seat (a street/trials seat)
k1 double bolt clamp
Koxx-One (k1) is up there in quality with Kris Holm 20" uni's, and the topic of which is better comes up often (as far as their 20" line goes)
__________________
Old 2011-03-05, 09:10 PM   #9
Masoncade
Mr. Nicejob
Masoncade's Avatar
thanks a ton! i decided on the green spirit.
Old 2011-03-05, 09:19 PM   #10
Dane M
Dane M's Avatar
A good choice, I'm sure you won't be dissapointed. But I will reccomend getting some pc pedals.
If you haven't ordered already, I'm sure other people will chime in. It's still pretty early in the day where I am, and there's forum members from all over the world here who get on at different times.
__________________
Old 2011-03-05, 09:22 PM   #11
Masoncade
Mr. Nicejob
Masoncade's Avatar
i won't be able to order until tuesday at the earliest (waiting for some checks to clear)
i've been looking and it seems to hold up quite well. i am officially excited.
Old 2011-03-06, 12:22 AM   #12
aarons
Eating a sandwich
aarons's Avatar
You might want some bike shorts. There's almost no padding on those seats. You'll likely be sore no matter what you do, but bike shorts will help.
aarons is offline   Reply With Quote
Old 2011-03-07, 12:50 AM   #13
OneWheelLess
weather is a fiend
OneWheelLess's Avatar
great choice on the uni!
i'd recommend getting some gloves and shinguards like these or and a helmet is not a bad idea either
edit: not sure why it formatted like this..
__________________
android power.
OneWheelLess is offline   Reply With Quote
Reply
Tags
etc., trials, uni, unicycle, versatile
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Is there any particular reason the forum is pink? AlisterBurt Just Conversation & Introduce Yourself 14 2011-02-09 01:32 AM
Is it worth the extra money to buy Chris holm bike 29 vs the nimbus 29? Tim Coin General Unicycling Discussions 14 2011-02-04 07:16 AM
Anyone know what this is? Help on a purchase Dane M General Unicycling Discussions 14 2011-01-25 07:42 PM
Copyright © 2001-2005 Gilby
Page generated in 0.10229 seconds with 11 queries
