Unicyclist Community
Reply
Old 2010-12-30, 06:04 AM   #1
IntoIt
Registered User
IntoIt's Avatar
Send a message via Skype™ to IntoIt
Why should I get new cranks?
I just bought a koxx spirit, the cranks are ISIS. I don't know how high a quality they are, so I want to know:
Is there an advantage to replacing these cranks with something better before they bend?
__________________
"Yes, I believe in luck, and the harder I work, the more of it I have."
-Thomas Jefferson
"You need chaos in your soul to give birth to a dancing star"
-Friedrich Nietzsche
IntoIt is offline   Reply With Quote
Old 2010-12-30, 06:14 AM   #2
johnfoss
North Shore ridin'
johnfoss's Avatar
None that I can think of, other than having new ones ready if/when they do. No waiting!
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2010-12-30, 06:23 AM   #3
feel the light
level 1 fat guy
It mostly depends how much you weigh
Lighter cranks are better, until you break them. Likely won't happen with ISIS cranks, unless you do lots of big drops, and or are a heavy person.
Assuming you are < 250 pounds and not crazy air, why not give them a go since you own them already? No harm in trying them.
feel the light is offline   Reply With Quote
Old 2010-12-30, 12:37 PM   #4
Pete23Mid
Registered User
You didn't say which model you have. I am well over 200 pounds and I have TruVativ blaze crankset without any problem. But I would say, I do not do that many jumps, as I am not very good at them. But I do always mount on my unicycle with kick up, so I guess they would break so far if they were weak.
Pete23Mid is offline   Reply With Quote
Old 2010-12-30, 02:37 PM   #5
sn0w
Registered User
Well I guess you could look at it two ways:
1: Ride them till you break them, If you don't break them you saved yourself the money!
or
2: Buy new (stronger) ones and sell your old ones, hopefully making back some of the money.. but what if your original ones never broke?!
(or maybe a third option, buy new ones and keep the originals as spare parts in case you break the replacement ones, ah! )
I'd go with #1, my 2c anyway.
sn0w is offline   Reply With Quote
Old 2010-12-30, 05:10 PM   #6
JacobSpera
Street
JacobSpera's Avatar
the cranks that came with the spirit should be just fine. If you are worried about them breaking or bending you can get the KH moments. Plenty strong cranks, i use them as a hammer sometimes
__________________
Team MAD4ONE
JacobSpera is offline   Reply With Quote
Old 2010-12-30, 06:58 PM   #7
maestro8
is what it is
maestro8's Avatar
A phrase comes to mind that would've saved me LOTS of headaches had I learned it earlier.
Repeat after me: "If it ain't broken, don't fix it!"
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2010-12-31, 06:55 PM   #8
Chrashing
O>OO
Chrashing's Avatar
Seems to me it's best to use the shortest cranks you like to ride with. So if your not sure that your current cranks are right, it's good to experiment with shorter cranks.
__________________
Regards,
Ken
Unicycles are flying machines!
24", 28", 32", and 36" KH frame based mutts.
26" inexpensive travel.
Chrashing is offline   Reply With Quote
Old 2010-12-31, 09:11 PM   #9
agentQ
Sam Haber
agentQ's Avatar
Send a message via AIM to agentQ Send a message via MSN to agentQ
Tubular Chromoly 135mm street.... mmmmm
__________________
Uneed Films
Whats up with Street and Flat?
the Unicycle Lab
agentQ is offline   Reply With Quote
Old 2010-12-31, 11:53 PM   #10
waaalrus
Registered User
waaalrus's Avatar
I'll be curious to hear how you got the street cranks off if you end up changing them. I was going to try some other cranks as an experiment but can't manage to thread on my crank puller.
waaalrus is offline   Reply With Quote
Old 2011-01-01, 12:01 AM   #11
IntoIt
Registered User
IntoIt's Avatar
Quote:
You can't install moments on many koxxs, including the green spirit. So says their website.
And to the guy who said "Shorter you are comfortable with the better," I know your opinion, but have no idea WHY that is your opinion. However, I do like the feel of short cranks, which is why my nimbus blizzard (main uni at the moment) has 110/125 moments, and I keep it on 110 99% of the time. I just like the feel of short cranks. Lots of Trialsers say that longer cranks are better. I wonder why they say this. If longer cranks made for better balance, it is odd that freestyle cranks never exceed 100cm.
These cranks are 135. I'm just going to try to get used to them, because I'm 5'9" 150 pounds and I'm not interested in jumping off of things much higher than I can jump ON, which is about 40cm MAX at this point, and since they probably won't break, it will be cool to have 110, 125, 135 and 140 (my 24" has a 140) options!
Glad nobody has offered any convincing arguments for changing cranks. I'm really not interested in spending right now.
__________________
-Thomas Jefferson
Old 2011-01-01, 07:41 PM   #12
JacobSpera
Street
JacobSpera's Avatar
The green spirit comes with a K1 light hub correct?
I have a K1 light hub on my current 20inch setup and ive yet to have a problem with it. Ive also put that thing through hell and back, on the old K1 hubs it was a bad idea to put KH cranks on them because the ISIS was different but now they got the problem fixed.
And honestly i doubt you will break the K1 cranks, they are pretty strong to start with
__________________
Team MAD4ONE
Old 2011-01-02, 05:09 AM   #13
aarons
Eating a sandwich
aarons's Avatar
Quote:
I found out in this thread that those cranks come with "self-extractors" that are supposed to make it possible to remove them without a crank puller. A nice side effect of this is that the threads are backwards, so you can't use a crank puller..
aarons is offline   Reply With Quote
Old 2011-01-02, 10:13 AM   #14
colinoldncranky
Look mum, no training wheel!
colinoldncranky's Avatar
Send a message via Skype™ to colinoldncranky
On the subject of breakages, I actually manages to crack thry my crankshat two weeks back, In all my years I have never seen a crank shat fail, and neither has the bike shop that is going to rebuild the wheel.
Unis do work the pedals and shaft a lot harder than most biking will do.
colinoldncranky is offline   Reply With Quote
Old 2011-01-02, 10:19 AM   #15
waaalrus
Registered User
waaalrus's Avatar
Quote:
Great information! Looks like my new uni came without these so I'll cross my fingers and hope the cranks last a good long while.
Reply
Tags
cranks
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Member Eamonn General Unicycling Discussions 3 2010-12-20 06:29 PM
this thread should be clicked upon theuniman500 Just Conversation & Introduce Yourself 10 2010-12-13 11:04 PM
Someone get this guy a unicycle Bondo General Unicycling Discussions 7 2010-12-10 09:25 AM
why doesnt the nightrider frame fit the coker wheelset? delta 224 Just Conversation & Introduce Yourself 4 2010-12-09 11:25 PM
New uni vid Lisa98 Unicycling Videos 14 2010-12-09 07:40 PM
Copyright © 2001-2005 Gilby
Page generated in 0.12058 seconds with 10 queries
