Unicyclist Community
Reply
Old 2010-05-22, 11:55 AM   #1
Mikefule
Roland Hope School of Unicycling
Mikefule's Avatar
My new KH29
Well, it was only a matter of time.
New KH29 arrived the day after ordering (thanks, Roger) and it had its first spin yesterday.
It arrived with a seatpost so long I had to cut about 7" off. (Don't ask me how I measured) The uni feels lighter than my old KH24 (I haven't weighed them). The Stout tyre is good and grippy but still rides OK on tarmac.
The two-hole cranks are very smart. Yesterday I rode on the shorter setting and the uni scooted about like a good 'un. Today I've put it on the longer settings in anticipation of a hilly ride in Merrie Sherwode with Gadge and Nov.
This model has a micro adjust seat fitting with no rails. All very tidy and easily accessible. Neat.
Pedals are weird: no flats for a 15mm pedal spanner. Will take a larger spanner, but I approached from the rear with an Allen key.
Frame neatly finished. The bearing clamps appear to be a more robust design than on my old 24.
So far, first impressions are good. It's obviously faster than the 24 (or the 26) and rolls over uneven ground nicely. It's more manoeuvreable than the 36, and fremounting in the rough is less of an excercise. My gut feeling is that on a mainly off road route, it will maintain a higher average speed than the 36.
It certainly looks like the KH concept has genuinely evolved* rather than changes for change's sake.
More follows.
*Or it has been intelligently designed. Let's not go there!
__________________
"I try to avoid UPDs, not do scientific research on them." Bruce Dawson
Mikefule is offline   Reply With Quote
Old 2010-05-22, 09:05 PM   #2
Into the blue
Groovy!
Into the blue's Avatar
Send a message via AIM to Into the blue Send a message via MSN to Into the blue
I bought my new KH29 a couple of weeks back.
I ordered it on Tuesday afternoon and it was on the doorstep by Thursday morning.
Roger and his gang of elves are the biz.
I also had to cut off around four inches from my seatpost.
I think they make these things for giants.
__________________
Quote:
Originally Posted by Harper
I wuld get a 20' trialls uni prolly with a blu tiar.
Get splined an a KH saet or ur a pansy.
Get trials cuz thaz whut i du n u mus wannaa whut i du 2.
lol...awwsum.
Into the blue is offline   Reply With Quote
Old 2010-05-23, 05:52 PM   #3
justtysen
Coasts Too Much
justtysen's Avatar
Kris Holm seems to keep the current product lists as streamlined as possible, hence all of the KH seatposts are 350mm long. That length has to serve the full range from 20" to 36".
Anyway apparently Mikefule is a "giant" of sorts.
justtysen is offline   Reply With Quote
Old 2010-05-23, 09:04 PM   #4
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
Nice one Mike - I also recently submitted to the lure of a 29er. Mine's mostly KH, with some changes for the sake of lightness for xc racing (you've probably seen the pics I posted in the "show us your muni" thread or whatever it's called - if it isn't called that then it should be)
On my mostly easy xc commute (with the odd rock garden thrown in) it's pretty much the same speed as my 36er, just because it's so much easier to control so I tend to ride the rocky bits faster. If I was a real speed demon on the 36er I'd probably make up some time on the couple of miles of road at the end, but I'm not (I chicken out at 15+mph and tend stick at 13 or 14).
The only bad thing (or at least, something I wasn't expecting) is that it's by far the bendiest of my unicycles, even including the 36er with normal width hub. I would have expected the aluminium frame to be at least as stiff as my far cheaper Nimbus 26, but it isn't. I suppose the wheel could be the bendy bit, but it's built with coat-hanger thick spokes (13 gauge?) so it shouldn't be. Very light though, which was my main aim (although it'd be even lighter with sensible 14g spokes KH!)
Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski)
"I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule)
rob.northcott is offline   Reply With Quote
Old 2010-05-24, 12:06 AM   #5
ally1776
UniMudder
ally1776's Avatar
Send a message via Yahoo to ally1776
I'm happy you guys like the new KH29 unicycle. That's promising I just bought one, hoping it arrives by the weekend. The upcoming weekend is a long weekend in the States and I'm kind of excited that I might have a long weekend to ride the new uni.
Mike what do you mean and please excuse my ignorance...
Does that mean "stock" pedals won't fit if we want to change them up?
ally1776 is offline   Reply With Quote
Old 2010-05-24, 01:47 AM   #6
justtysen
Coasts Too Much
justtysen's Avatar
Quote:
The threads are the same so you can fit any standard pedals (9/16") to the cranks. According to Mike's post it is just that a normal pedal wrench won't fit and so a different size may be necessary in order to remove and install those particular pedals. However, as noted there is a secondary method of removal using a hex key on the inside of the crank arms where the pedal has been inserted.
The pedals can be interchanged with any others you are likely to have, however you may or may not have the tools necessary to remove or reinstall them.
Edit: Just checked the pedals included on the KH29. They have wrench flats that are 17mm apart instead of the standard 15mm. However they claim to be wide enough to fit most adjustable wrenches, so if you have an adjustable crescent wrench (normal wrench) you should be able to use that.
Old 2010-05-24, 01:52 AM   #7
tholub
Totally Doable
tholub's Avatar
Quote:
The KH frame is quite stiff; if you're getting flex in the wheel, perhaps your spoke tension is too low.
tholub is offline   Reply With Quote
Old 2010-05-24, 02:07 AM   #8
scott ttocs
Registered User
scott ttocs's Avatar
My 29 " KH also had a lot of flex. After reading about some of the issues with new KH bearing holders, I sanded off the paint from the inside of the bearing holder and reassembled it, carefully tightened the up the bearing holders on the bearing. I got the bearings to fit much better and ended up removing a lot of the flex in the unicycle. It is now a much better ride.
Scott
scott ttocs is offline   Reply With Quote
Old 2010-05-24, 02:11 AM   #9
ally1776
UniMudder
ally1776's Avatar
justtysen, thanks I do have several sizes of wrenches and a rather large set of hex keys. Thanks for clarifying as I am not good at the mechanical part of unicycling, slowly but surely I am learning. Thanks again.
Old 2010-05-24, 04:57 AM   #10
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
The JC Pedals have a 6MM Allen or 17mm Flats. The claim is that they're stronger.
Max_Dingemans is offline   Reply With Quote
Old 2010-05-24, 04:58 AM   #11
tholub
Totally Doable
tholub's Avatar
Quote:
It's a silly claim. Who's ever broken a pedal at the flats?
Old 2010-05-24, 09:15 AM   #12
rob.northcott
Mainly XC Muni
Quote:
It's possible, but I wouldn't say it's particularly slack (it feels as tight as my Nimbus 26" wheel). I tightened it up a bit when I first had it, but perhaps it could take a bit more tension. I'm a bit wary to go too tight without a gauge though - it needs to be reliable, don't want to be breaking nipples or spokes on rides.
Rob
__________________
Old 2010-05-24, 06:48 PM   #13
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
I got a 2007 29" frame a while ago and it is definitely flimsier than my old Yuni frame but the weight difference is huge. Not sure if the newer frames are stiffer.
__________________
saskatchewanian is offline   Reply With Quote
Old 2010-05-24, 08:10 PM   #14
rob.northcott
Mainly XC Muni
Quote:
Scott
That was true of mine as well - I think they must be specified without allowing for the paint thickness. I haven't actually scraped the paint off mine (yet - keep thinking about it) but after a few fittings and removals and doing the clamps up tighter than normal it did get much better. I reckon the remaining flex is the frame and/or the wheel.
Quote:
That's how I look at it - even if it is a bit bendier than my Nimbus (and that doesn't flex visibly at all even under heavy stomping on climbs) it's considerably lighter.
Rob
__________________
Old 2010-05-24, 09:25 PM   #15
Mikefule
Mikefule's Avatar
Haven't noticed any particular flex on mine. Done two rides on it, with some fairly varied rolling terrain. I do find the KH Freeride saddle a bit sore though.
__________________
Reply
Tags
kh29
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
My new unicycle video! Lisa98 Unicycling Videos 28 2010-06-01 08:36 PM
[For Sale: North America] New KH29 rim and Schwalbe big apple tires brycer1968 Trading Post 2 2010-03-30 04:27 AM
my new website bobousse General Unicycling Discussions 2 2009-12-23 10:31 AM
my new camera tim_desmet Unicycling Videos 6 2009-12-18 04:54 AM
my new video DSchmitt Unicycling Videos 15 2009-12-11 08:14 AM
Copyright © 2001-2005 Gilby
Page generated in 0.09220 seconds with 10 queries
