#1 |
Flex Your Head
chipped Rims and brakes
On my KH 29er XC rim, I seem to have a little chip on the braking surface. Maybe in two areas. They are uneven dents with rough edges that must have been from the uni hitting a rock during a bail/UPD/fall. I was experimenting with putting brakes on the 29er and I can definitely hear/feel when the pads go over the chip on the braking surface.
What are my options here? Can I sand the problem area down some? Do I just need to deal with it or is there something I can do to make braking better? The chips are very small, and I never noticed them before adding the brake (I kind of want one now that I am using a geared 29er off road).
__________________
-James |
#2 |
Unicycles on my mind...
sand paper and then emery cloth should help. that's where I'd start. remove the rough edges so they don't chew up your pads. You'll probably feel the thump as it goes around, but it shouldn't bother anything beyond your nerves.
check around the damaged areas to see if there are any cracks or hairline fractures coming from the damage. Don't try to unbend aluminum. |
#3 |
Scott
once they're sanded i doubt you'd notice them, especially if your muniing.
__________________
This is no longer a blank signature, that is all |
#4 |
Pedal Pedal Crash
Just using the brake is a lot like sandpaper. You probably won't notice the chips after a few long downhills riding the brake.
#5 | |
Mainly XC Muni
Quote:
![]() Rob
__________________
"Hedgehogs - why can't they just share the hedge?" (Dan Antopolski) "I would absolutely recommend a 29er to anyone who didn't prefer a larger or small wheel." (Mikefule) Last edited by rob.northcott; 2010-05-11 at 10:18 AM. |
#6 |
I try not to be that bad. I feel guilty enough milking the disk thread to death, but I try to keep that stuff in there. I feel most would benefit from disks, but that's another thread!
#7 |
Registered User
Use a black emery board (fingernail file). Get a course/medium. And if you want a Pink Fine. Any Walmart/Wagreens/RiteAid will have them.
Using a fingernail emery board with keep your braking surface true and flat and you will only knock down high spots. Put some masking tape on both sides of the rough areas so that you only sand where you need to.
__________________
The only constant in nature is Dr House's epiphany 10 minutes before the end of each show. |
| Tags |
| brakes, chipped, rims |
Similar Threads
| [For Sale: North America] Magura HS33 rim brakes, new and used | brycer1968 | Trading Post | 56 | 2010-09-18 04:37 AM |
| [For Sale: UK] 4 trials rims (black, orange and gold) | simonb | Trading Post | 2 | 2010-05-07 04:14 PM |
| i chipped my glasses | epistolize | Unicycling Videos | 5 | 2007-02-24 05:54 PM |
| Americans getting chipped. | Tim Morin | Just Conversation & Introduce Yourself | 22 | 2006-04-12 03:46 PM |
