Unicyclist Community
Reply
Old 2010-07-30, 02:42 AM   #151
jtrops
Registered User
Quote:
Originally Posted by MuniAddict View Post
Please tell us the other parts used to make that handle! I need something short like that for my 29er!
Quote:
Originally Posted by Mountainuni1 View Post
+1 I Like that 20" frame handle. Do Tell us how this is done chickenreincarnated who is golden.
"Sorry Chome Avenir 20" sitting in the corner all by yourself "... You're about the be on the wrong end of a hacksaw in the basement.
Unless I'm missing something it looks like the small uni frame is connected to the brake lever post on a KH rail adapter.
Hardware:
  1. Rail adapter with brake lever mount
  2. Small uni frame, or maybe even a bike fork with a slot cut in it.
  3. Seatpost clamp
__________________
"A properly ridden unicycle is like an object in orbit: constantly falling but never landing." -Diogenes
jtrops is offline   Reply With Quote
Old 2010-07-30, 09:49 AM   #152
kb1jki
Unicycles on my mind...
kb1jki's Avatar
I have a 24" that we could use to those ends with a dual bolt seat adapter. it's a 22.2mm seat post diameter and will likely slip on the end of your rail adapter brake lever mount (which puts the brake lever far away from your seat nose handle anyway). Is the chrome one in your basement still working, because my 24" has a dead, broken wheel and isn't worthy of a replacement wheel...
__________________
Retrofit Disc Brakes to your existing unicycle today!
kb1jki is offline   Reply With Quote
Old 2010-07-30, 02:18 PM   #153
goldenchickenreincarnated
Registered User
Very little was required. I hacksawed off the bearing holders from my old 20" chromed unicycle. Then I sawed off the saddle post tube about 5 cm. But if you're not going to use the "beak handle" on the saddle you won't need to do that operation. However, if you hack it off you must make a new slit in the tube (yes, hacksaw again). Then you put a saddle clamp on the tube and push it on to the brake mount below the saddle. Tighten the clamp and it will sit firmly. When you upd the handle will be stopped by the "beak handle" so the weld on the brake mount will not crack. I hope. If you don't fancy the chrome you can dress the handle with an old tube (use soap). Some petrol or alcohol will blacken the rubber.
__________________
Since I am anticipating the unanticipated, it is not a problem. hugo
goldenchickenreincarnated is offline   Reply With Quote
Old 2010-07-30, 03:04 PM   #154
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Quote:
Very cool. thanks for posting that. But isn't that a 29er? And the only reason I probably won't make one like that, is because I don't want to go back to using a (heavy) rail adapter. I'll probably just use my stoker stem mounted directly to my seat post, and go from there.
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2010-07-30, 03:37 PM   #155
Registered User
Yeah, it was made for the 29er but by the time I had refurbished my 36er I didn't want to use my old (and even heavier) T7 so I moved it. The handle is a wee small for the big wheel, but fits well on the 29er on smooth trails. If one wants a longer handle you can use a 24" frame. I have found myself (with hacksaw in hand) staring at my old (and no longer used) Coker frame. Anyway, good luck with your own project.
__________________
Old 2010-07-30, 04:12 PM   #156
jtrops
Registered User
If there is a stoker stem with an inside diameter of 1 1/8", or 28.6mm, you could pretty much do this same thing, but insert the seat tube from the donor uni frame into the stoker stem rather than around the brake lever mount.
__________________
Old 2010-07-30, 05:53 PM   #157
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Quote:
Like this? I used my kh handle for the time being. I have it way shorter than when it's on my 36er, and I'd like it even shorter still, but I don't want to cut it down. I would also prefer a bit more upward angle on the stoker, but this is all i have at the moment. I don't really want to get in to adding more stems if I can help it.
__________________
UniGeezer.com
My videos
Old 2010-07-30, 06:17 PM   #158
jtrops
Registered User
Attachment 43016
That's elegant. I'm a fan of attaching to the seatpost, and this is on the right track. What about using the old Scott MTB clipon bars instead of regular bar ends. They would give you more reach at the bar end, and you could adjust the angle at that point. The MTB version had clamps that were made for 22.2mm bars, and it looks like these ones on ebay would do the trick. You could lose the arm rests.
__________________
Old 2010-07-30, 06:34 PM   #159
unireed
Reed Breuer
unireed's Avatar
i also have bike armrests like that one and i was wondering how i could mount it to my coker big one. does anyone have pictures of how they did it?
__________________
"I'm probably not advanced enough to have thoroughly tested it while riding, but I'm unadvanced enough to have very thoroughly tested it while falling." -uniShark
I ride for Christ-opher Walken
unireed is offline   Reply With Quote
Old 2010-07-30, 06:34 PM   #160
MuniAddict
Not "2" Tired
MuniAddict's Avatar
I tried aero bars on my 36er, and considered them for my 100 mile ride. But I really didn't like the feel of them, so I just used the kh handle alone, which was very comfy on the long ride. Using them on my 29er would make the reach much too long, which I don't really want for my 29er; just something a bit longer and more comfortable to hold on long rides than the lift handle.
__________________
UniGeezer.com
My videos
Old 2010-07-30, 06:55 PM   #161
unireed
Reed Breuer
unireed's Avatar
do you have any pictures of how you attached the aero bars?
__________________
Old 2010-07-30, 07:05 PM   #162
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Quote:
Very easy. They attach directly to the "T" of the kh handle. You can even keep the bar ends attached, and just turn them around. I never did use them for my 100 miler. Just didn't like the "feel" of them. The kh handle alone was perfectly fine...and lighter!
http://unicyclist.com/forums/showpos...&postcount=132
__________________
UniGeezer.com
My videos
Old 2010-07-30, 07:26 PM   #163
jtrops
Registered User
I wasn't suggesting to use them as aero bars. My idea is to use them as longer bar ends so that you could get a bit more angle adjustment. You could cut them down if they are too long. If you want to keep the bend you could heat them up to release them from the clamp, cut them down, and re-glue them. You could even flip them over to get a flatter profile.
__________________
Old 2010-07-30, 07:38 PM   #164
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Oh, ok. Good idea!
__________________
UniGeezer.com
My videos
Old 2010-07-30, 07:59 PM   #165
unireed
Reed Breuer
unireed's Avatar
so i guess lone aero brs wouyldnt work for me. i dont have KH or any handlebars as it is now.
__________________
Reply
Tags
36er, mumpitz, post
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Post Your GUni Here munirocks General Unicycling Discussions 34 2011-02-15 11:00 AM
post your WINTER UNI here! uniShark General Unicycling Discussions 2 2009-11-24 11:25 PM
Copyright © 2001-2005 Gilby
Page generated in 0.16432 seconds with 11 queries
