Unicyclist Community
Reply
Old 2010-02-19, 06:16 PM   #1
DSchmitt
Human Gyroscope
DSchmitt's Avatar
do you think it's worth it to get my 07 kh frame welded?
it broke at the typical spot right above the crown.
this guy says he can do it for $40. i know nothing about aluminum welding or the prices for it. is 40 just a complete ripoff?
he also added that it still may break..which is why i probably won't do it. any other trials riders had their kh frames welded? do they hold up after welding?
DSchmitt is offline   Reply With Quote
Old 2010-02-19, 07:49 PM   #2
bouin-bouin
Didier
bouin-bouin's Avatar
KH frame are made of 7005 T6 aluminium, T6 means they receive an heat treatment after welding in order to improve strengh at the welds. If you get it repeared, I guess it will remain weak. I would prefer to replace the frame for the latest design
__________________
http://monocycle.info
http://teamcdkmonocycle.blogspot.com/
MUNI KH26" & KH29" both with Oracle disc brake, ROAD KH36" with KH dsic on Spirit crank
my goal : a 3 geared 29" to have only one uni for all kind of rides :-)
bouin-bouin is offline   Reply With Quote
Old 2010-02-19, 10:23 PM   #3
jaco_flans
Trials & Muni!
jaco_flans's Avatar
Send a message via MSN to jaco_flans
It worked with mine I got it re-welded in fall, it's still going strong and I love it! I dont think it'll break soon!
__________________
Jakob F.
Trials 'n Muni 'n Trials 'n Muni
jaco_flans is offline   Reply With Quote
Old 2010-02-20, 05:45 PM   #4
lobbybopster
Registered User
lobbybopster's Avatar
Frame weld (Aluminum)
First off, $40 bucks is reasonable for a quality weld, Which includes metal prep and set up with the correct weld filler rod. Typically about $80- $120 an hour at a shop. (Not everyone who welds has the correct equiptment)
Second, Because of the properties of 7005 alloy, Yes a solution heat treat process is normally done to bring it up to T6 temper. But a repair weld on a heat treated frame will be strong enough, and most likely bend in failure the next time if it is not quench cooled after weld, but allowed to cool by itself on its own time. (important) Becuse rapid cooling makes the aluminum. Dead Soft (Annealed)
With this said, only repair if you like this frame and Money/Cost, is an issue!
lobbybopster is offline   Reply With Quote
Old 2010-02-20, 09:51 PM   #5
4umfreak
Registered User
4umfreak's Avatar
I'd say for $40, you've got nothing to lose! Maybe it lasts a year - is it worth it then? Will you be in a better place to buy or replace it with another?
-M
__________________
- 4umfreak
4u2c.it a simple, fun and free Url shortener with publishing to Facebook and Twitter.
Geagle Search Engine a unicyclist.com inspired search engine. (kh longneak vs shortbeak)
4umfreak is offline   Reply With Quote
Old 2010-02-21, 01:21 AM   #6
lobbybopster
Registered User
Weld repair?
Quote:
-M
+1, and a little paint!
Reply
Tags
frame, welded, worth
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
32h rim w/ 48h hub What do you think. jtrops General Unicycling Discussions 5 2010-03-29 04:51 AM
what do you think? aidanteleki Trading Post 29 2010-02-27 06:12 PM
Who do you think will win today? siafirede Just Conversation & Introduce Yourself 1 2010-02-07 09:16 PM
What do you think? JoeBike General Unicycling Discussions 11 2010-02-06 05:16 AM
Wanting to get back into it scoobysnacks General Unicycling Discussions 4 2009-10-30 08:46 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07062 seconds with 10 queries
